Old 02-22-2014, 12:08 PM   #1
Coley
Coley's Avatar
Mechanical 'Catch of the day'
well....I lucked out a bit today so I thought I'd share.
I scored a complete 350-4bbl engine w/ 90% of the accessories with it (HEI ignition, exhaust manifolds, fuel pump, starter, ring gear, intake manifold, air cleaner, waterpump, balancers, etc, etc)....on a brand new engine stand...for $80.
Plus as an added bonus I got a brand new 60 gallon (John Woods) hot water heater for $100 from the same guy (Electrician cleaning out his shop!!).
Now the motor is nothing too special...I believe its a 1975 Truck engine that was the guys grandfathers and it was supposedly running well when removed...but I needed an engine stand so I figure thats worth $30 in the deal...taking the motor down to a $50 commitment.
I'm not sure what I'm going to do with the motor yet...maybe compression test...then sell as a 'builder' or?
Still.....who doesn't like or can't resist a good deal?...LOL
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 02-22-2014, 01:05 PM   #2
bigmac73
bigmac73's Avatar
Re: Mechanical 'Catch of the day'
Coley
if you dont need the engine i say invest a couple of hundred bucks on a bearing/ring and gasket kit and throw some paint on it and you might get 700 to 900 bucks for it , provided the heads and block are in good shape
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
