I have a radical idea!
Question about 71 - 72 4X4 6 lug wheels.
What size was the standard wheel size for 71-72 disc brake 4X4 K10's and Blazers? I see stock trucks with a narrow 15" rims with hubcaps, but I don't know the size of them.
The reason I ask is when I change my '68 over disc brakes I want to run a 6 lug rotors, and I have recently found out that the stock 67 - 70 15 X 5.5's won't clear the calipers. I am going to run 15 X 8" 6 lug steelies in the rear, but I want to stick with a narrower rim on the front, but I would like a wider rim than the factory 5.5's were.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
![]() Join Date: Aug 2003
Re: Question about 71 - 72 4X4 6 lug wheels.
Pretty sure same width just different offset. If not they are no more than 6".
Here's a good thread that will give you a few more options.
http://67-72chevytrucks.com/vboard/s...e+6-lug+wheels |
I'm pretty sure my Jimmy factory wheels were 15x7. Currently they are mounted on my '69 short step with the original '69 hub caps. I would think this would work fine on your '68 with discs.
This is the only pic I could find easily. The spare is the original '69 wheel.
15x6" was the base wheel size, 71-72 K5, K10 Pickup and Suburban.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
