Too high of gears to pull a trailer?
I'll be getting out of the military the end of this year and driving back to indiana. The trip is approx. 2000 mile. I have a 72 k10 with 307 diffs. Is it unreasonable to think I can pull a car carrier with Honda civic on it? The car will be crammed pack with my belongings so total weight on trailer will be roughly 3000lbs with about another 1000lbs in the bed. Running 33" tires and a th350/350.
Re: Too high of gears to pull a trailer?
Unless you have a weak 350 I'd say you should be ok.
I'm no expert but I've pulled 6,000 plus pounds with a worn out 305 no clue what gears were in it but I say you'll be fine just use common sense
![]() Join Date: Feb 2012
Thanks for your service! Check your brakes prior to your trip, don't get in a hurry and easy on the down grades.....
http://67-72chevytrucks.com/vboard/s...d.php?t=509467 2008 Dodge 3500 Blue Tech 2013 Challenger SRT8 392 1972 Landcruiser Rock Crawler LS1 1969 4X4 Resto Mod |
#5 | |
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
My two cents; thank you Sir for serving our country. we appreciate you doing that.
Thank you for your service. Millions of Chevys and GMC in the 70's and very early 80's did the exact thing you are talking about. All day, every day. You will be fine. Good luck Enjoy the road trip. Jim
Thank you for the replies and thank you for paying your taxes
![]() Join Date: Oct 2009
Good luck on the trip, should work out fine. You might find it a little annoying going uphill, but it's doable. Wish I was moving back to Indiana! By the end of the year, the snow will have melted, maybe. Or be back again. Where in Indy?? VH was indeed the band back in that time frame.
#10 | |
![]() Join Date: Mar 2012
i would think you would be fine and get a decent MPG with those gears, unless you hit some foot hills or Mountains,
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
#13 |
Thank you for your service! I did something similar a number of years ago - moved from Seattle to Phoenix driving a 72 K10 SWB (350/4 spd/3.07 gears), pulling a 71 K5 Blazer using a tow bar. It worked okay, though we did have trouble overheating when we got to northern Arizona due to hot weather and a tired motor in the K10. We ended up disconnecting and drove both rigs separately the rest of the way.
I've also towed a +/-3000 lb boat with the Blazer (350/350/3.07 gears) and it did okay though was a dog on the hills - usually a second gear pull. edit to add: 32" tires Last edited by JGray; 03-05-2014 at 08:00 PM. Reason: tire size |
#14 |
My 72 short stepper with 3:08's was my regular [daily] tow rig, I towed 3/4 tons, 4x4's, big block Impala's, you name it I towed it. Had to get a bit of a run at some grades such as west bound I-8 out of Ocotiilo but always made it.
#15 |
Too many projects
You should be fine, but you're going to be at more than 3000lbs for a trailer, most car haulers are in the 1500-2000lb range empty. Just make sure to keep an eye on your gauges, and adding a trans temp gauge may not be a bad thing. Also ensure that your cooling system is in good shape for some of the uphills you may have to pull.
FYI: When I EASd I used a 70 El Camino w/ 350/TH350/3.08s with a Sportster in the bed to tow dolly my 63 Chevy II from San Diego to South Dakota. Pulled just fine, but trans temp got a little high in the mountains so I had to stop a few times to let her cool down and I ended up doing a lot of I40's hills during the night when it was cooler.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
