56' shortbed stepside vs. 61' shortbed stepside?
Guys,
Does anyone know whether or not a bed off of a 56' shortbed stepside will work on a 61' shortbed stepside? I was of the understanding that they would interchange, but I was looking at some sheetmetal parts in a catalog last night and they listed separate part #s for the actual bedsides between these two trucks. The fender #s and tailgate #s were the same, though. Any help is appreciated. Thanks!
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
Re: 56' shortbed stepside vs. 61' shortbed stepside?
the stepside beds were pretty much the same from late 55-87. late 55-66 were the same except for taillights. mounting locations in the bedwood may be different, but the bed will work fine
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
fenders, taillights and some minor changes to the bed sides. front bed panel and tailgates were universal from late 55-87
Thanks for the response!!
That's what I was thinking, also. It threw me last night when I saw two different part #s listed for the bedsides. I couldn't for the life of me figure out what would be different between them. Thanks again!!
I had to replace my 66 RR fender so I bought a 58 to use thought every thing was fine. During assembly I found that the 66 fender is deeper then the 58. I had to offset the bed to make it work.
Thanks for the heads-up on that.
60-66 Nut
![]() ![]() Join Date: Mar 2007
The frame mounting points on the crossills are going to be different between the two. The '61 will be wider.
#8 | |
But Found Her 25yrs Later!
I wonder if they are deeper for a deliberate reason like wider wheels or something.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
I just measured from outside of lip to outside of bed wall. The 66 fender is 3/8 deeper.
Thank you all for the help.
John, I guess redrilling the mounting holes is all it would take to use the older bed on the 61', huh? If so, that's easy enough. 66farmer, hopefully 3/8" narrower on each side won't be enough to cause any tire and wheel fitment problems. Thanks again, guys, for the help!!
The mounting holes are in the wood anyways....so makes it easier!!
Yes sir! And easier in this case is better!
| Bookmarks |
