Old 02-23-2014, 11:48 AM   #1
Motorhead-47
Motorhead-47's Avatar
Hood Hinge Question
I need to replace the worn out hood hinges (pins are sloppy) on my 67' and am looking for advice on whether I should go for genuine GM parts or whether one of the aftermarket hinges is "as good" or perhaps even better. I've read several times where the current production OEM hinges are not near the quality they used to be and some are saying that certain brand non-oem hinges are actually better quality than what you can get at the Chevy dealer today. Thoughts and opinions please.
Ideally I'd like to find a set of new-old-stock hinges but suspect that is highly unlikely that I would locate a set....at a decent price.
1967 Shortbed Stepside - GM Crate 454HO 425HP/500 lb-ft, long tube Hedman ceramic coated headers, serpentine belt drive, Built 700R4, 12 bolt 3.42 with Eaton posi, 4 wheel disc brakes, OldAir A/C. 69' Corvette Lemans Blue. Painless Wiring Harness. Everything from the ground up is either new or rebuilt!
Motorhead-47 is offline   Reply With Quote
