![]() Join Date: Jan 2008
GMC Cab compared to Chevy cab
Does anyone know if there are any differences between a 71' GMC 3/4 ton cab and a 71' Chevy 1/2 ton cab? I assume they are the same, but I just want to make absolutely sure. I know the 71' Chevy has a raised area where the rear view mirror mounts that none of the other cabs had, is the GMC the same? Thanks in advance for the help!
![]() Join Date: Oct 2012
Re: GMC Cab compared to Chevy cab
IM pretty sure there the same, but there are hi hump and low hump. and AC and NON AC.....
lets see what others say....
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
That is pretty much it in a nutshell. A/C or not and High Hump (removable cover) or Low Hump (formed floorpan). Factory Bucket Seats have a different floor build for buckets. The roof panel is different if a truck has factory Roof Marker Lamps. Headliner slots, and Cargo Lamp are detail differences that can be added but kind of hard to remove.
But then there is that pesky question on VIN plates too.....
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 02-23-2014 at 05:58 PM. |
Thanks for the help guys.
