Old 02-23-2014, 02:05 PM   #1
1971 3/4TON
1971 3/4TON's Avatar
Used DELCO brake pads
Okay, so I replaced my brake pads on my '71, and I realized something unique- These brake pads are stamped DELCO (not AC Delco). Another particularly unique feature of each pad is the single ridge that arches with the contour of the brake pad.
I found this especially interesting since on both of my rotors, there is a uniform groove. I don't know if this is how GM, Dana, or Spicer made the rotors, or if if this was caused by the classic design of the brake pads themselves.
Anyway, these brake pads would be great for someone who has knowledge of refurbishing older brake pads, or would simply like to use them as a template to help redesign the older DELCO brake pad with the arched ridge.
I am asking for $10 to ship these pads.
In the event that nobody wants these brake pads, I would still be very interested to know why there are ridges on these brake pads. Furthermore, I would like to know if the ridges on the brake pads created a single, uniform groove on each rotor, or if the rotors were designed with a groove, by the manufacturer, with the idea of precision engineering and compatibility with the stock rotors. Thanks. -Dylan
1971 3/4TON is offline   Reply With Quote
Old 02-24-2014, 01:30 AM   #2
boynton
boynton's Avatar
Re: Used DELCO brake pads
All 71/2 are this way the grove is on purpose
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
