02-23-2014, 02:41 PM | #1 |
WTB powerglide linkage
I am looking for the linkage that goes from the trans to the block, measures 11 5/8 ", mine grew legs. I can make it easy enough with heim joints but original is preferred, thx.
02-23-2014, 08:26 PM | #2 |
Re: WTB powerglide linkage
check with board member uncle. I think he had some 3 or 4 weeks ago.
I have a set too, but it`s from a 66 impala. |
02-23-2014, 08:55 PM | #3 |
Hopefully this will broaden your search, I looked up the GM part number and from the trans linkage to the bracket assembly its part number 3830310 which the book says 1965-1971 truck with PG, then looked up that number under passenger car in a 69 parts book and it says its the same number for 1964-1969 Nova Chevelle and Camaro with 8 Cyl PG and 1965-1969 Impala. Heres the pages from the parts book group 4.050 .
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
02-23-2014, 09:00 PM | #4 |
02-23-2014, 09:22 PM | #5 |
Thanks for the info, that definitely makes the search easier.
02-24-2014, 06:49 PM | #6 |
I'm pretty sure I have the entire original linkage set from my old powerglide. I'll take a look and let you know.
02-24-2014, 08:23 PM | #7 |
02-25-2014, 11:24 PM | #8 |
Should have one also ,will look tomorrow and let you know.
Go Fast and Have Fun.!! My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185 |
02-26-2014, 12:37 PM | #9 |
If sickboy and contagious each have a powerglide shift linkage setup available, I would be interested in getting in line behind the OP for one of the linkage sets.
02-27-2014, 07:14 PM | #10 |
02-27-2014, 08:04 PM | #11 |
I am confused as to what the linkage on the left is, the bracket is the correct one for the frame to shifter linkage on trans, the rest ??
02-27-2014, 11:18 PM | #12 |
Have to look again ,that may be for the carb on the in line six.!! lol
02-28-2014, 10:17 AM | #13 |
If LT1burb is not interested in that 6 cylinder linkage I would buy it from you. Im building a 6 cylinder truck that was missing several of those pieces .
02-28-2014, 10:19 AM | #14 |
I am not, it does not have the part I need.
02-28-2014, 05:38 PM | #15 |
LT1 Burb is this what it looks like ? the rod and both ends. May not be the right one ,this longer than 11 5/8" ,this looks like it goes from the column down to the bracket for the 6 banger. I will look for more.!!
Go Fast and Have Fun.!! My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185 Last edited by contagious102; 02-28-2014 at 05:45 PM. |
02-28-2014, 05:31 PM | #16 |
60-66 if you want the carb linkage 30 plus shipping .
02-28-2014, 09:01 PM | #17 |
Ok, I will take it. Sending pm
02-28-2014, 07:04 PM | #18 |
Look at part#19 in the picture above , it has 2 ball pivots, one on each end.
02-28-2014, 07:59 PM | #19 |
I think the one for the six and the v8 must be different.I will look though.!!
