Old 02-23-2014, 03:33 PM   #1
LuckyScott
LuckyScott's Avatar
How to get a key to a chevy that was lost?
Help, A friend of mine bought a 1970 Suburban that had been sitting and has no keys. Looks like someone replaced the column with a tilt column and the ignition is in the column, not on the dash like my suburban. I told him to get rid of the column but he thinks there is some kind of trick to get the ignition out and replace with a new ignition.
Does anybody know the trick?
LuckyScott is offline   Reply With Quote
Old 02-23-2014, 03:46 PM   #2
vectorit
What?
vectorit's Avatar
Re: How to get a key to a chevy that was lost?
Is the ignition switch in the dash still wired up?
Or is the harness all rewired to work with the column ignition switch?
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 02-23-2014, 03:47 PM   #3
Jake1971
Jake1971's Avatar
I suggest recruiting help from a qualified locksmith to pick the ignition lock so it can be turned to the accessory position, at this point you should be able to push the detent retainer pin inwards and extract the lock. Once the old cylinder is removed a new one with keys can be simply installed.
1971 Bone Stock C10 project "Jake"
1997 Sierra SLT factory short bed "Silver Bullet"
Jake1971 is offline   Reply With Quote
Old 02-23-2014, 05:21 PM   #4
72MARIO
72MARIO's Avatar
I took my door lock to a lock smith and had him make a key for it. That worked in my ignition
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-23-2014, 08:14 PM   #5
CG
BlahBlahBlah
There are You Tube videos on how to remove the ignition lock cylinder. Its pretty easy to do. I had a tilt column with the key in the column and I wanted the tilt but not the key there. Found the video online and it came out pretty easy. Moved the key to the dash.
Old 02-24-2014, 09:16 AM   #6
68panelman
68panelman's Avatar
He needs a key to move to the ACC position. ^^^
68panelman is offline   Reply With Quote
Old 02-24-2014, 12:00 PM   #7
LuckyScott
LuckyScott's Avatar
That is correct, most videos show that you use your key, and then remove the ignition. Without the key, it is much harder. I did find one video that shows that you remove the wheel and the turn signal parts. You will find a screw inside that will allow you to remove the ignition without a key. Then just buy a new ignition. Not sure how it will work, but we are going to give it a try. If it does not work, I told him to pull the column and take it to a column rebuilder.
Old 02-24-2014, 12:11 PM   #8
junkmandan3
junkmandan3's Avatar
With the ignition in the dash, does anybody know any tricks, other than sacrifice the retaining bezel, then replacing the switch and tumbler? I'm working on a 67-72. The ignition and door tumblers usually are different in the half dozen or so that I've owned.
junkmandan3 is offline   Reply With Quote
Old 02-24-2014, 12:14 PM   #9
SCHRUMGMC
SCHRUMGMC's Avatar
Dont mean to hijack but I am taking the Door lockout itself to go get a key made.I took off the Door panel and took off the door latch.I see the little Door lock and need it out to go get a key made..I'm in a hurry got a lot to do today and i cant get the door lock cylinder out for my '59
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 02-24-2014, 03:25 PM   #10
67 Burb
67 Burb's Avatar
I agree with 72mario, in my 67, the same key works in the ignition, the front doors and the rear barn door.
Bob
1967 2wd Burb, 350/TH350, 3.73 posi
67 Burb is offline   Reply With Quote
