Old 02-23-2014, 04:55 PM   #1
ng64
ng64's Avatar
getting ready to install my camaro subframe
I know this subject has been discussed plenty but I'm getting ready to install my subframe an was wandering is there any reason why I can't remove my front fenders hood and cab to do this. My buddy told me to leave it all on the truck so I could make sure my wheels will be centered in the wheel well. I see no reason to leave it all on. Thanks for any advice. Also have my new engine ready
ng64 is offline   Reply With Quote
Old 02-23-2014, 05:51 PM   #2
MARTINSR
MARTINSR's Avatar
Re: getting ready to install my camaro subframe
Your buddy is right, absolutely right. You want the thing at ride height, I used all thread to replace the shocks then tightened up the nuts to suck the springs down to where the rubber bumper was about an inch off the frame leaving the lower control arms level, just as they were on the Camaro in checked.
With the wheels on the sub frame I rolled it into place. With the rear of the truck at the ride height I planned, I was able to put the sub frame up against the frame and VERY IMPORTANTLY using a protractor put the upper control arm shafts at the same angle as they were on the Camaro! This is a mistake often made. Guys will be so focused on how cute the sub matches up with their frame thinking THAT is what is most important and it's not. Making sure the geometry is correct is most important. If you screw this up you need to get offset control arm shafts to correct it, and some times that doesn't even work depending on how screwed up you got it.
So after the sub is in place I put the front sheetmetal on to make sure the wheel looked right in the wheel opening. The measuring tape means NOTHING at this point, how does it LOOK? A quarter inch too far back can make for a horrible look! A little too far forward you can get away with but if it's too far back, just a hair it looks like crap. I had it too far back. As I remember I moved it about 3/8" and I was very happy I had not made the mistake of thinking it could be done without hanging the sheet metal.
Now, what year is this truck? If it's an AD, I HIGHLY recommend to go with a different front end, the Camaro is too wide and you have to cut up the rad support so much, making a new one makes more sense.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 02-23-2014, 10:15 PM   #3
ng64
ng64's Avatar
Thanks for the advice. My truck is a 57. The wheels I have on it now are just some I borrowed don't plan on usin them. So if I didnt check the angle of the upper control arm shaft while the subframe was under the camaro what do I do? Seems like I read somewhere they should be like 7 degrees? Thought I throw in some pictures even though I'm ashamed of my truck compared to everyone else's on this forum. But I love it anyway. Any more advice will be greatly appreciated. Thanks
Old 02-23-2014, 11:03 PM   #4
MARTINSR
MARTINSR's Avatar
I don't know what angle they should be at, study it. It's a shame it's not still in the Camaro.
On your truck, don't ever be ashamed of what your truck is, more trucks in this forum started out NOT looking as good as yours!
Brian
1948 Chevy pickup
Old 02-24-2014, 01:09 AM   #5
oldman3
oldman3's Avatar
Brian
I second that. See if you can goole what the anti-dive angle is for the camaro, it should be around 5 to 6 degress, but not sure...Jim
oldman3 is offline   Reply With Quote
Old 02-24-2014, 08:28 AM   #6
Spblack
Spblack's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=219621
check here
1959 Chevy Apache (sold)
1958 Fleetside Current
My builds:
http://67-72chevytrucks.com/vboard/s...d.php?t=606412
http://67-72chevytrucks.com/vboard/s...=1#post7560906
Spblack is offline   Reply With Quote
Old 02-24-2014, 08:36 AM   #7
buggy5872
buggy5872's Avatar
If you leave the tails on the subframe and they are tight against the bottom of the truck frame, it will have the correct angle. If you are not going to do it that way, Set the subframe up on jack stands, make the tails level, then measure the angle.
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline   Reply With Quote
Old 02-24-2014, 10:02 AM   #8
Indian113
Indian113's Avatar
This is the simple way to do a sub clip.
Indian113 is offline   Reply With Quote
Old 02-24-2014, 10:03 AM   #9
ng64
ng64's Avatar
Thanks for all your help guys. My plan is to leave tails on subframe and weld them to my stock frame making sure my angle is right hoping it ends up flush with my stock frame
Old 02-24-2014, 10:06 AM   #10
ng64
ng64's Avatar
Indian113 do u know the measurement from the cab mount bracket to where u cut ur stock frame by chance? I was gonna cut my directly behind the existing bump stops on my stock frame
Old 02-24-2014, 10:45 AM   #11
Indian113
Indian113's Avatar
That isn't my frame. It's a friend of mines 57 frame. If you can try to get a hold of Red Foreman in Australia he used the pics I have and did a 56. He could give you a lot of help. Check out his build in the build section. I have more pics of that frame if you pm your e-mail addy I will send you a file
Old 02-24-2014, 12:48 PM   #12
Mac the Yankee
I used a plumb bob to mark the wheelbase on the floor (and mark the center line of the frame), then added approx 1 5/8" to the wheelbase to better center the wheels in the fender.
marking center line of the frame on the floor really helped when we positioned the subframe- dropped the bobs out of the center holes in the subframe and lined it all up square!
Mac the Yankee is offline   Reply With Quote
Old 02-24-2014, 03:04 PM   #13
Iceburgh
Iceburgh's Avatar
I have done 8 of these on 47-55 1st. None of them had the anything on them in front of the fire wall. The rad support is critical that it is the same distance with the new sub frame. All sheet metal bolts off of it. Make up a jig to use and attach it to the fire wall. Build from there. As far as wheel center....measure that before cutting off the old frame.
I believe it is 116" wheel hub center to wheel hub center
Iceburgh is offline   Reply With Quote
