Old 02-23-2014, 05:03 PM   #1
70chevytruck
No fuel pressure
New tank.
New sending unit.
New rubber lines.
Steel lines blown out.
New fuel filter.
New fuel pump...installed correctly.
1970 gmc 2500....402...rebuilt.
This is the second fuel pump in 3 weeks.
Shouldn't the fuel filter be full? Mine is empty...fuel spurts in when it feels like it.
No pressure on gas cap when I open it.
Frustrated in Texas.
70chevytruck
70chevytruck is offline   Reply With Quote
Old 02-23-2014, 05:13 PM   #2
terry b
terry b's Avatar
Re: No fuel pressure
If you pore gas in the carb and get it running will it stay running?
terry b is offline   Reply With Quote
Old 02-23-2014, 05:37 PM   #3
bigmac73
bigmac73's Avatar
i would pull out the push rod and check it out.
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 02-23-2014, 05:53 PM   #4
imjeff
imjeff's Avatar
Check everything from tank to fuel pump by siphon, then look at the ushrod and make sure it moves when you roll the motor over by hand.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 02-23-2014, 06:00 PM   #5
terry b
terry b's Avatar
Sounds like a air leak before the pump. Without a check valve the fuel will drain back out of the carb after it sits.
Old 02-23-2014, 07:30 PM   #6
70chevytruck
Connected a fuel line from pump to gallon of gas....still have issue.
Must be bad fuel pump again.
70chevytruck
Old 02-23-2014, 07:32 PM   #7
bigmac73
bigmac73's Avatar
maybe somebody put the wrong push rod in and it is too short? i would pull it out and compare with new one at parts store
not for sure if BBC and SBC are the same length
Mike
Old 02-23-2014, 09:13 PM   #8
hamjet
hamjet's Avatar
It does sound like the fuel pump push rod is hanging up by how you describe it. I'd pull the pump and see if the rod moves in and out freely with my finger, if it does make sure its a bb pump, a question, why is it the second f pump in 3 weeks?
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 02-23-2014, 09:50 PM   #9
sstaten69
sstaten69's Avatar
maybe a bolt that might be to long in the front of the block that is holding the fuel pump rod?
sstaten69 is offline   Reply With Quote
Old 02-23-2014, 10:21 PM   #10
litew8
litew8's Avatar
flat pump cam eccentric?
project: "my happy mess"
litew8 is offline   Reply With Quote
