![]() Join Date: Sep 2007
tilt column rebuilding
I have a tilt colum thatt came from a floor shift so no shifter on the colunn. But I need to take off the turn signal switch housing and possably replace some loose bearings. Can someone send me a link to show how to tear these down properly.
1967custom |
![]() Join Date: Mar 2012
Re: tilt column rebuilding
i would send a PM to Kevsclassics on here, he rebuilds and refurbishes columns, and does an outstanding Job , I am sure he would help you out
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
x2
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
The factory service manuals have a great deal of information on the columns.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
I got a 70 factory manual. Ill look it up thanks.
Ok and im gonna look up kevsclassics now
1967custom |
X2; on the sevice manual, excellant exploded view....just a couple tools youll have to build to get it apart. Did mine awhile ago, and just a couple peices need to have proper orientation to go back together, but mine was not a floor shift.....if you can post up pics, always helps to see what your into...
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
If you want to do it yourself, one more vote for the "factory" service manual for the model of vehicle that the tilt came out of. Normally the tech writers who write those do not assume that the person in the shop following the instructions ever worked any component of the vehicle before and write instructions step by step accordingly.
It might not hurt to get the digital camera out and take photos as you go taking it apart. They don't cost anything and my just solve that question of does this go this way or does it go that way.
Definatly ill be taking pics during teardown. Its time consuming but a lifesaver.
1967custom |
