![]() Join Date: Mar 2012
my wheels need your help
on my front wheels i have brake dust that feels like it is embedded in the aluminum, I have tried a green scrub pad with wheel cleaner/purple power/nano polish/degreaser and many other products, i still can not get them to fully clean up
Any thoughts or idea? should i take a SOS pad to them i dont want to jack up the surface, but they do feel rough around the brake dust.
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Re: my wheels need your help
You can try oven cleaner that might work or you can wet sand in steps 400,600,1000,1500,2000 grit sand paper then mothers polish and they will look brand new but the process is long and boring
^ this is the answer if you want to save them.
'72 Chevrolet Step Side 350/TH350, '63 C10 Step V8 '74 Trans Am 400, '80 Trans Am Indy Pace Car Mercedes AMG S55, SLK230 Kompressor, GL450 '96 Dodge Indy Ram Official Indy Truck '99 Porsche 911 Carrera |
did i get some cheap knock offs, i have never seen this with aluminum wheels before
They look like an ultra type 164, I had a set in high school. Give them an acid bad, sand, sand, sand, and polish. They will only look so good since there cast. Other option is there only about $100/each
Brake dust is very corrosive. That is why its important to keep alloy wheels clean and coated. At this point they are going to need to be cleaned to at least a machine surface.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
well i would like to upgrade to these, but momma keeps popping out kids, so i dont think it will happen this year or so, not for sure about the back spacing on these?
http://www.summitracing.com/parts/su...3gm0/overview/
#8 | |
BlahBlahBlah
68 GMC 2500 stepside LWB 250CI |
True but who am I to say no... I dont think men get headaches as much as women do.
BOHICA
Sand,sand,sand,sand, and wet sand progressively finer grits and then mothers on a powerball and they will SHINE! Way cheaper than new wheels, all it cost you is time and beer while sanding!
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig! |
There's a few threads on the first page here:
http://67-72chevytrucks.com/vboard/f...splay.php?f=65
#13 |
It's alsways something.....
![]() Join Date: Nov 2008
Stop by your local truck stop where they polish the big rig Alcoas. No problem for them to make them look like mirrors. Should be relatively cheap compared to the manual labor involved
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
