02-23-2014, 08:27 PM | #1 |
rear end decisions
Got a 69 c10 with an original non posi rear end. Not sure how strong they are. I hear a lot of pros and cons about them. Found a 9" rear housing on CL for $50 and was wondering which housings are stronger, the 9" or the one I got in the truck now?
truck is being built for 95% track usage. |
02-24-2014, 01:18 AM | #2 |
60-66 Nut
Re: rear end decisions
Probably 90% of the guys will say go with the 9". But you will have to dump quite a bit of $$$ into that $50.00, 9" to get it narrowed, setup and under your truck.
02-24-2014, 01:27 AM | #3 |
Yeah I know it will be a pretty penny to build it up, but won't it cost about the same to do it with the rear end that's under my truck now?
03-02-2014, 11:09 PM | #4 | |
Then comes the big one. Can you do the work yourself and do it correctly or will you need to send it to a diff shop? If you can cut the ends, replace them with ford ends and new axles you can probably do the entire diff including an upgrade to an Eaton posi carrier for about $900.00. If you have to send that 12 bolt to a diff shop, the cost is going to be nearer to 1500.00 and, for that money, I would either build or buy a nine inch built to the width you need with all of the correct bracketry. It's a matter of your skills and money. mostly money. |
03-03-2014, 12:17 AM | #5 |
60-66 Nut
What kind of power will you be putting to the rear end? What size tire are you planning on running? There are a few guys here that are running the truck 12 bolt, with some respectable times.
03-04-2014, 01:31 AM | #6 | |
Right now the motor has about 650 foot pounds of torque and 525 hp. By the time I actually dish out the money on a rear end, I'm hoping to be close to if not more than 1,000 foot pounds of torque and close to if not more than 900 hp. My goal is to get up to around 1,500 foot pounds of torque and more than 1,000 hp without nitrous in order to stop building up the motor. Size of rear tire I'm planning on running is 33.5" x 17"-16 goodyear eagle slick or a 33.0'' x 22.50'' - 15'' with a 17'' tread width Hoosier quick time d.o.t. drag tire. |
03-04-2014, 04:17 PM | #7 |
Hollister Road Co.
I used the 12 bolt that was in mine. Had it narrowed and had ford Torino ends put on. Axles, bearing ends, narrowing all done was about 500.
03-04-2014, 09:41 PM | #8 |
Registered Truck Offender
Your gonna need one serious rear for 1500 pounds of torque. Forget about anything stock and go straight to Mark Williams site and break out the mastercard. Nothin in the stock world is going to tolerate that. I have a 9" with as Strange Pro spool and gear and aluminum centersection under a 2600 pound chassis and 797HP and IMO it's is not far from it's limits.
Williams site has some great info on what you need to keep it safe at various ET's, power and weight.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
03-05-2014, 01:51 AM | #9 |
60-66 Nut
I agree with Marv D
With those kind of power numbers, a 9" isn't goint to cut it. You're going to have to really step it up to something like one of Mark Williams' own differentials. I don't know if a Dana 80 or a built 10.5" 14 bolt would tollerate that or not. I would suggest looking thru this thread to see what you are going to need in a rear end. http://www.67-72chevytrucks.com/vboa...d.php?t=469935
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 03-05-2014 at 01:56 AM. |
03-05-2014, 02:07 AM | #10 |
Checked out Mark Williams site at their rear ends. As for choosing gear ratio, not sure about those. And with wheel to wheel dimensions, are they asking inside rim to inside rim or inside tire to inside tire or what?
Now as far as bolt patterns go, you think it might be possible if they could make it 6 lug instead of 5x5 or 5 1/2x5? |
03-05-2014, 10:46 AM | #11 |
I like Alstons site for their tech sheet. It give you a good work sheet to start with.
http://www.cachassisworks.com/Attach...structions.pdf
03-05-2014, 11:39 AM | #12 |
mini truck racer
Im gonna say Dana 60 as a minimum . If you are headed to the power levels posted above , then no need to build the rear end twice or three times . 35 or 40 spline , 10 to 10.5 ring gear , 5/8 studs and as many as possible considering fullsize truck weight and big power . I believe currie has a size calculator that will fill in the blanks .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
03-05-2014, 04:12 PM | #13 |
You can do that with a 9 inch. I wouldn't use a factory one though. Get a Fab 9 or have your friend weld back braces to good tubes. Then a Moser or a Strange center section and you are set.
Chris |
03-08-2014, 12:17 AM | #14 |
Moser Dana 60 w/35spline axles,Spool,4.30 pro gear, Billet 1350 yoke, big bearing Impala weld-on ends. Holding up well with transbrake and low 1.30 60's on a 31x14 Goodyear slick.
'72 SWB 3,600# Indigo Blue , Sunset Racing Pump Gas 582" 1,002hp / 833tq ,Transking 400 W/ Transbrake, Moser Dana 60 w/4.30 Old Motor: 60'. 1.43 1/8 6.58@104.64 1/4. 10.42@127.10 Nitrous: 60'. 1.28 1/8. 6.15@ 112.02 1/4. 9.75@ 136.32 Last edited by RICKSRAT; 03-08-2014 at 12:22 AM. |
03-08-2014, 06:18 AM | #15 |
mini truck racer
Trying to find the Like button for this ^^^^^^
03-08-2014, 02:50 PM | #16 | |
Also, lets take a few steps back. As for the power I'm running now, my set up is, 650 ft pnds torque 525 hp, built turbo 400, stock 12 bolt non posi rear end, and 28x12x15 goodyear slicks on 15x10 tims. Trailing arm suspension. Front and rear suspension has not been modified in any way yet. The information that has been put in this thread is great. Still want to hear more about rear ends and such for the kind of power that I want to make in the future. But, as for what I'm making now, I'd like to also know what would be a good rear end, and what kind of power it can handle. Would I just be better off buying or building a rear end that can handle the power I want to make in the future, that way I don't have to worry about blowing it out at any point of time? |
03-08-2014, 05:52 PM | #17 |
http://www.moserengineering.com/hous...d-package.html
The Moser Dana 60 package now has an option for 70-72 Chevy trucks brackets if you want a bolt in. I'm currently at 700tq on motor and + nitrous nearing 1,000tq. I had built the 12bolt truck rear w/33spline moser axles and twisted splines and bent housing tubes twice. And reason for a Dana was it's not a 9" . What motor combo are you running?
'72 SWB 3,600# Indigo Blue , Sunset Racing Pump Gas 582" 1,002hp / 833tq ,Transking 400 W/ Transbrake, Moser Dana 60 w/4.30 Old Motor: 60'. 1.43 1/8 6.58@104.64 1/4. 10.42@127.10 Nitrous: 60'. 1.28 1/8. 6.15@ 112.02 1/4. 9.75@ 136.32 |
03-08-2014, 08:06 PM | #18 | |
Current set up is 555 cu in big block, around 950 HP naturally aspirated, TH400 (full manual valve body, no brake) and 4.10 gears. MW spool, axles and c clip eliminators, welded tubes. Best ET is 9.85 at 136 mph, at 3950 lbs. Car has been going 11.80s or faster since 1990. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-08-2014, 08:49 PM | #19 |
mini truck racer
The sterling 10.25 comes to mind also .
03-10-2014, 02:19 PM | #20 |
A good 9" will do it just fine. Use an aluminum center section with the big pinion support, a pro gear and 40 spline gun drilled axles. Now the big problem is getting the rest of the truck to hold it. With that power level I would put a full chrome moly all round tube chassis under it. 4 link rear with a strut front. You can get away with a really good power glide but I would put a bruno or lenco drive in it. Those power numbers look like blower/turbo numbers with that huge torque or something well over 700 inches.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
03-10-2014, 07:20 PM | #21 | |||
10.25? Quote:
As for motor, keeping it under 700 Cubic Inches, but will either be single or twin turbo non-alcoholic. |
03-10-2014, 11:31 PM | #22 |
I'd invest in a posi or spool for your dogleg 12 bolt. Who knows??? It may take it... A 12 bolt is pretty tough
03-11-2014, 07:00 AM | #23 |
If you look at the rule book you are getting into the very regulated chassis specs. You are also getting into a very high dollar chassis. The last top sportsman car I put together was a tad over 130K out of the owners pocket and that was a used Don Ness car and a new motor and trans. Just tell you chassis builder what power you have and let him handle the suspension and rear end. Don't be shocked at a 40K bill from him for a roller.
Jimmy
03-11-2014, 01:55 PM | #24 |
I don't know PG,, will a 1000 pounds of torque put him below a 8.50 chassis cert? It for sure depends on it hooking and the power getting through the chassis, suspension and all the way to the track. As you well know, a lot of things between this 1000 pounds of flywheel torque and the track can keep the combination WAY slower than anyone might expect.
Still a 8.50 cert is going to be deep into his pocket. A roller 8.50 car in the 2500ish pound weight is still beckoning $15k $30k+ just depending on the quality / age of the build. And buying a used build is about 30¢ on the dollar these days. I honestly feel your $'s are very VERY realistic!! Low&slow,, prepare for sticker shoc in what the rest of the package is going to cost!
03-11-2014, 08:42 PM | #25 |
Well the under 700 inches and a single or duel turbo making up to 1500 but at least a 1000 is 1300 plus HP. With a 706 making about 1300 hp and a 1000 ft pounds at about 2550 lbs with the driver we went 7.19 at 192 in not so good air. A truck wont go through the air like a grand am but if I had that much power like he wants to build and and could not run 7.80s some one is getting fired. A good chassis design and someone who knows what to do with it will be needed and 25.1 car will be what he has to have.
Jimmy
