Old 02-23-2014, 08:33 PM   #1
Smurfeh
Oil pump priming
Alright getting close to starting up my second 5.3. The both engines are from 2007's new body style with AFM. Now this engine has sat on a stand for 3 years.. I would assume that I would need to prime the oil pump like I would on an old sbc? Usually I would have just pulled the dist and put a long common screwdriver down and prime it that way, but with the newer engine obviously doesn't have a dist.. what have you guys done to your engines after they have sat for 3+ years on a stand? obviously don't want to fire it up without seeing oil Px within the first 10 seconds.. suggestions?
Smurfeh is offline   Reply With Quote
Old 02-23-2014, 09:09 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Oil pump priming
Disable the ign & fuel to the engine, remove the spark plugs....crank the starter 15-20 seconds at a time, until you see pressure @ the guage. After that, plug it all back in, & fire her up? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-23-2014, 09:32 PM   #3
truckdude239
truckdude239's Avatar
Your going to have to turn it over cause the oil pump is driven off front the crank
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 02-23-2014, 11:04 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
There is a tool for this, and you can build one yourself.
Its a force primer, sorta like a reverse brake bleeder, or the lift pumps you would use for lubing a rear end.
Ls1tech and youtube have how-to's on making one.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-27-2014, 04:01 AM   #5
mcmlxix
Collector of Projects
mcmlxix's Avatar
HERE is an example that uses an electric pump.... notice the port where the primer pump is attached...
HERE is the Garden Sprayer method...
Rich
1972 K5 Blazer CST Click HERE
Old 02-27-2014, 11:44 AM   #6
Angryman117
Originally Posted by crazy longhorn View Post
disable the ign & fuel to the engine, remove the spark plugs....crank the starter 15-20 seconds at a time, until you see pressure @ the guage. After that, plug it all back in, & fire her up? Longhorn
Did mine the same way, no need to overcomplicate it.
Angryman117's
47 Chevy Build
89 Silverado Z71 LS Swap (sold)
Angryman117 is offline   Reply With Quote
Old 03-02-2014, 08:35 PM   #7
Operatorfailure
I have done the pull coil wires and plugs crank the key until you get pressure on two different swaps and no problems. I'm not going to lie though, I was nervous both times.
My 68 Stepper build
Operatorfailure is offline   Reply With Quote
Old 03-02-2014, 09:06 PM   #8
crazy longhorn
Not to "muddy the waters here"....I can see the point to do a power prime on that high end engine. On a stocker, that has already run in, I don't see the need to? That roller cam , stock lobes, or mild profiles just wont have any issues that we have seen with the flat tappet hyd grinds? If the bearings are lubbed, you should be good to go Longhorn
