Old 02-23-2014, 09:34 PM   #1
eric8
Park/Neutral/Reverse/Drive signal to ECM
The LS swap book I am reading mentions that the ECM needs to know when the vehicle is in gear or not in order to determine idle speeds, etc. However, reading the Chevrolet Performance E Rod harness instructions, it makes no mention of this signal going to the ECM. I plan on using a crate LS3 with the Chevrolet performance engine controller and harness. Any idea how the GM harness is getting this data? See here: http://paceperformance.com/files/pdf/19244807E-ROD.pdf
eric8 is offline   Reply With Quote
Old 02-23-2014, 10:59 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Park/Neutral/Reverse/Drive signal to ECM
The signal is off of the Neutral safety switch, which is on the transmission portion of the harness. It can be run without (I don't use it), or can be hooked up to an aftermarket shifter or switch. Its just a contact switch.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-23-2014, 11:26 PM   #3
eric8
So where is the neutral safety switch on the 4l60e? I guess I've read so much on this subject even I'm confused. You have the neutral/park safety switch on the factory steering column. Then if you have a truck transmission, you have a gear position switch on the drivers side of the tranny. But if you have a car 4l60e there is no switch? I am going to be running the GM Supermatic transmission controller and harness with a 4l60 or 4l70e. So you are saying the transmission controller takes this input from its harness, and then relays it to the ECU?
Old 02-24-2014, 01:10 AM   #4
truckdude239
truckdude239's Avatar
Mines not hooked up its not really needed
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 02-24-2014, 01:41 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
You only have the NSS on the steering column if you had a column shift vehicle. The same vehicle equipped with a floor shift would have one in the shifter assembly, or could very well have one on the Range indicator (the second plug on late model electronic trans harnesses).
You don't NEED any of them, but you only want to run 1. Because its just a contact switch, it can be mounted anywhere that connects when in park. You could put it on a toggle switch if you REALLY wanted to, but it would just be weird and probably a recipe for headaches.
on the range selector
Aftermarket NSS for custom shifters
And I couldnt' find the column shift one, but they all wire up the same. You can use anything you want to make the connection.
