Old 02-23-2014, 11:57 PM   #1
Mattacorn1
Mattacorn1's Avatar
Rear end diffrences
Is a 63 1/2 ton 10 bolt the same width as a 65c10 rear-end? I have a 65, but someone has put a rear-end out of an Iroc under it. Its to damn narrow for me though.
How hard is it to drill and change the lug pattern on an axle? Im wanting to go from 6 to 5 to match the front disc brake conversion.
1965 C10
1966 GMC
1992 C1500
2002 Yukon Denali XL
2008 3500 GMC Duramax
2011 3500 LTZ Duramax
Mattacorn1 is offline   Reply With Quote
Old 02-24-2014, 02:31 AM   #2
Captainfab
60-66 Nut
Re: Rear end diffrences
A '63 C10 will have a 12 bolt as will a '65 C10. Those are basically interchangeable, but they will have different panhard bar mounts and different length panhard bars. To install a '63 12 bolt under your '65, the panhard bar will need a slight bend at the end that bolts to the frame bracket. Otherwise everything will bolt up.
Changing the bolt pattern on the axles is not something the average guy can do in his garage. The original holes will need to be plugged and machined flat, as well as the hub register machined down. Then the new hole pattern accurately drilled the correct size for the new studs to be pressed into the flange. I would only consider doing this if the wheel bearing surfaces are in good condition. If you need new axles, you will also have to change the spider gears in the '63 12 bolt.
If you could find a '71-'72 12 bolt it would be a simple bolt in and already have the 5x5 bolt pattern. However they will be 1.5" wider than the '63 to early '70 differentials. A '73-'87 differential will also work, but you would have to weld on the trailing arm mounts and a panhard bar mount. These will also have the 5x5 wheel stud pattern and are also 1.5" wider.
