![]() Join Date: Sep 2013
wtb: new ps rag joint ASAP
can someone lead to the right place to buy a ps rag joint. changing out my 71 manual to ps. Have everything done, just need the joint. i counted 31 splines.
Thanks |
Re: wtb: new ps rag joint ASAP
Maybe this will help, its a link to rebuild your rag joint.
http://67-72chevytrucks.com/vboard/s...d.php?t=614332
Scott |
Scott, I think he is in the same spot I am. The manual box rag joint is a different spline count n diameter. But some good info there rebuilding a used one.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
low n' slo
![]() Join Date: Mar 2009
i have one but not sure if this is the one you need..
http://shop.advanceautoparts.com/p/l...202/18340127-p Its brand new in the box
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
![]() Join Date: Sep 2007
Theyre readily abail. At parts stores like autozone if yoyre in a hurry
1967custom |
Yup they are. I asked for a ragjoint for a 77 chevu 1/2 ton 2wd with power steer.
1967custom |
low n' slo
I thought i counted mine right and was still wrong. The difference all depends on the gearbox youre buying. I had to order a few to make sure i got the right one.
advanced auto had 2. One for manual that was 3/4 and one for ps that was 13/16. I ordered the ps one. Hope its right. Picture looked right.
RockAuto shows two also. Let me know how you came out. I need one also.
http://www.rockauto.com/catalog/x,ca...2BA1%2BCARDONE
I am in the same boat.
Did anyone come up with a Dorman part # ? Cal. |
i slid mine on but want to completey get it together before i say it works. Will be this weekend. it is from adv auto. they have a manual one and a ps one
#13 |
If it slides on the shaft you should be good.
Post a part number after you confirm it please. I am going to try RockAuto's.
#14 |
Did anyone come up with a part #
I know the ones you were looking at were Lares. Does anyone know the Dorman part# I have a 31015 but doesn't want to slide on and don't want to force if wrong one. I have the 68-76 P/S box pre metric. Cal. |
#15 |
The Lares worked like a charm. Slide on easily. Had to tap the bolt a little to het it to slide across the spline/neck but all is good. Now the pulley fiasco is another story...
#16 |
#17 |
The Lares from RockAuto I ordered worked like a charm. Slid on perfectly. The link I posted is the one I ordered.
No tapping required.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" Last edited by Sammy; 03-12-2014 at 12:06 PM. Reason: @ |
#18 |
Yes 201...$21 after shipped.
#19 |
If you can't find the Lares.
I used Dorman #31015. It was tight and needed to be tapped on. |
