Old 02-24-2014, 12:13 PM   #1
El Rondo
Air conditioner compressor problem..help?
Couple of days ago, while movin' on down the road, I started smelling some pretty serious burning rubber. Figuring I'd be walking soon, I prepared for the worse, since the smell was stronger and stronger (figured a belt was going). Made it to the house, luckily, and noticed the belt that goes around the fan and the air conditioner compressor was pretty thin and rubber shavings were everywhere (motor: 350 small block, V8). Changed the belt. Figured the problem was because the "Frigidaire" compressor was vibrating...I found a missing bolt on the mount and replaced it...nice and snug.
This morning she fired right up and I was getting ready to back out when I heard some rattle under the hood. When I checked, I traced it to the pulley for the belt at the end of the compressor. Right behind the hub is appears that a washer disc or something had torn loose and was now rattling around. I tightened the hub but it had no effect as the piece between the hub and the magnet is loose (gasket?) and is rattling noisily.
My question: Can I remove this washer/gasket, and simply not use my air and be in good shape? I never use air conditioning anyhow. Really won't bother to replace it for some time. Even in the summer, I don't care for air conditioning..just go with "redneck air system" (windows down..vents open). Can I run the vehicle fine without this system in place? Best to remove the belt, etc.?
Thanks for any tips...
El Rondo is offline   Reply With Quote
Old 02-24-2014, 12:23 PM   #2
Coley
Coley's Avatar
Re: Air conditioner compressor problem..help?
Most people simply remove the a/c belt when the compressor starts showing problems...which usuallly originates at the front end of the compressor with the clutch/pulley assembly.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 02-24-2014, 12:26 PM   #3
El Rondo
That's exactly where the problem is. I'll just remove the belt then and not sweat it....or WILL sweat it, pardon the pun. I'll have to pull that assembly apart to get that rattling washer loose though...unless I can cut it out of there...I'll have to study it more.
Thanks for the tip!
Old 02-24-2014, 01:07 PM   #4
El Rondo
...eh...it won't rattle when it isn't turning I suppose...duh. Forget it...i'll mess with it way down the line.
Thanks.
Old 02-24-2014, 06:07 PM   #5
Wrenchbender Ret
This rattleing washer might be part of the clutch brg. The bearing is probably shot. You can remove the belt but it may cause the other belt to slip at the water pump. It doesn.t have a very long contact distance on the pulley.
Wrenchbender Ret is offline   Reply With Quote
Old 02-24-2014, 08:58 PM   #6
El Rondo
Hmm. Took that one loose and blazed down the road...so far so good, but I better watch for that slipping. Thanks for letting me know!
