Old 02-24-2014, 10:43 PM   #1
truckdude239
truckdude239's Avatar
temp fitting question
So i got my new guages today i bought the autometer 2277 m12x1.50 to 1/8 adapter i had to drill the center out but the temp prope doesnt reach out of the adapter will that matter?
Also thread sealer or no thread sealer on the temp sensor?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 02-25-2014, 01:21 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: temp fitting question
I'd imagine having the probe protrude into whatever it is you measure would be beneficial to getting an accurate reading.
Is this oil temp, trans temp or coolant temp? I suppose technically as long as the heated fluid can touch the probe it will give a reading, but having it tucked inside the adapter may lead to an air bubble, or unusual fluid flow in that spot, giving erratic signal. As an example, having a temp sender partially unscrewed gives erratic readings, I would think this could as well.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-25-2014, 02:45 AM   #3
truckdude239
Its the coolant prope
David fuller
2000 Tahoe 5.3l 378
Old 02-25-2014, 09:15 AM   #4
littlevictories
I use teflon tape on coolant stuff. Not much pressure, but leaks p*** me off.
littlevictories is offline   Reply With Quote
Old 02-25-2014, 12:27 PM   #5
Matt Cramer
With coolant temperature, I wouldn't be too worried about lack of coolant flow - the coolant will conduct the heat well enough the reading should be pretty accurate.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 02-25-2014, 10:51 PM   #6
mooseknuckles
mooseknuckles's Avatar
I had to do the same with mine...works fine...
mooseknuckles is offline   Reply With Quote
Old 02-26-2014, 01:49 PM   #7
truckdude239
this is what im working with
David fuller
2000 Tahoe 5.3l 378
Old 02-26-2014, 03:25 PM   #8
mooseknuckles
yep.....you have to remember it's coolant, so it's gonna find it's way in there...at least that was my thoughts....
Old 02-27-2014, 12:45 AM   #9
crazy longhorn
Fabricate till you "puke"
The auto meter sensor (made to screw into that adaptor), does not set as deep, as the one that you drilled? Still , it is about right on, with the stat? The stat is around 190 ish....(205 on/195 off , on the elect fans). The guage does not dance around longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-27-2014, 12:53 AM   #10
truckdude239
Okay that's what I wanted. To hear. Did you use telffon or sealant on yours? I've been told it will effect the ground but factory Senors had sealer on them new
David fuller
2000 Tahoe 5.3l 378
Old 02-27-2014, 01:57 AM   #11
crazy longhorn
That copper washer should seal it....that said, I did use a little thread sealant, not tape.... Mopar, or ARP, but just lite on the threads, as said the copper washer should seal it? longhorn
Old 02-27-2014, 10:48 PM   #12
Jon01
Jon01's Avatar
I didn't use sealer on mine, just the crush washer.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Jon01 is offline   Reply With Quote
