Old 02-24-2014, 11:55 PM   #1
1970customcampercst
1970 c20 cab bushing problem
Restoring truck has been 7 year project ,cant get box & fender body lines to line up cab to high in back & to low in front. Have new bushings & in right need help!
1970customcampercst is offline   Reply With Quote
Old 02-25-2014, 12:55 AM   #2
dbash
Re: 1970 c20 cab bushing problem
Shim one or cut the other. It sounds crude but you wont be the first one to do it.
The key is figuring out which one needs to be adjusted so the entire body line is straight.
The rear Bushings on my Cab had to be cut a quarter inch after triple checking to make sure the front did not need to be shimmed. I bought a back up pair just in case though....
Good Luck! Sounds like your getting close.
http://67-72chevytrucks.com/vboard/s...d.php?t=509467
2008 Dodge 3500 Blue Tech
2013 Challenger SRT8 392
1972 Landcruiser Rock Crawler LS1
1969 4X4 Resto Mod
dbash is offline   Reply With Quote
Old 02-25-2014, 01:28 AM   #3
1970customcampercst
Thanks i got a Polly kit & tried it & it was off then got stock rubber kit & it's off about the same fender tight to door on top & 1in on bottom
Old 02-25-2014, 01:30 AM   #4
dbash
I would test run the bed too before you cut anything.... Just so you dont have issues later.
1969 4X4 Resto Mod
Old 02-25-2014, 01:42 AM   #5
1970customcampercst
Thanks again I have box sides on & cab is about 1/2in high I also have a 71 c20 thought about pulling in shop & measuring between the two so I can level out the 70 c20
