02-25-2014, 04:07 AM | #1 |
1-barrel to 2-barrel carb
has anyone taken off there 1-barrel carb and replaced it with a rochester 2-barrel carb? if so how was it? gas mileage , better running, ect. thanks.
02-25-2014, 10:48 AM | #2 |
Re: 1-barrel to 2-barrel carb
I'm guessing inline six? I modified a 1 bl slant 6 with a 2 bl carb off a 318. It did have a lot more pep. I also had added electronic ignition and headers. I wasn't going to split the engine open to change the cam, so I didn't add a four barrel. It was just a fun project with some spare parts kicking around the shop. With that said I'd love to find a cheap 235 intake manifold. A few hours a drill press and a Bridgeport, I'll have a nice 2 bl intake.
02-25-2014, 12:17 PM | #3 |
I am running a stock 292 with a 600 Edelbrock, clifford intake and headers and an hei and the motor runs like a dream. lol. Mileage when cruising at 55...probably around 16 ISH. The 292 wasn't the best on milage until you put an over drive on. I used to have a 350 CFM Holley 2 barrel on the 292 and it ran great as well. You'll notice a bigger difference if you convert to headers as well.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
02-27-2014, 04:46 PM | #4 |
do you mean putting the 2bbl on with an adapter or is there a rochester 2bbl that will bolt up? im also trying to find the best option to get rid of my 1bbl.
02-27-2014, 05:01 PM | #5 |
i was asking if anybody took off there 1 barrel carb and put on a 2 barrel carb. ? just wanted to see if anybody did that and if so how was the outcome?
02-28-2014, 12:18 PM | #6 |
I bought an adapter from Trans adapt which adapts a 2 barrel holley down to a single barrel 194-230-250-292 manifold. It worked fine. What 6 cylinder do you have?
02-28-2014, 12:20 PM | #7 |
I've done it with my 292 I6 and worked nicely....
02-28-2014, 06:28 PM | #8 | |
02-28-2014, 06:31 PM | #9 | |
02-28-2014, 06:57 PM | #10 |
Ran a tad better..easier starts(with HEI) and accelerated a tad better. Slightly better mileage. I used a 350 holley...if I was you i'd do a 500 cfm 2 barrel holley or 500 cfm edelbrock 4 barrel mounted on a clifford intake and add headers. You'' get the best mileage outta a 4 barrel And headers. I probably was getting around 14 and now probably 16.
02-28-2014, 07:35 PM | #11 |
I installed a Webber 32/36 with adaptor on my stock 1 barrel manifold. I also installed Tom Langdons cast iron split headers. The increase in power is very noticeable. I could not be more pleased.
09-04-2014, 02:16 PM | #12 |
I'm looking to do the same, but the split iron headers from Tom Langdon did make a pretty big difference. my 292 right now is getting 11.5 on the highway at 55.
09-04-2014, 02:39 PM | #13 |
It's Better With Nitro
I recently did the conversion on my Pontiac Trophy 4 and it made a night-and-day difference. My Rochester was flighty (running and starting) and I was having to tune it constantly. My mileage hovered inconsistently between 12 mpg - 15 mpg on the freeway (Powerglide), depending on what personality it had that day. After the conversion, the engine starts right up, idles better than ever, and I get a consistent 18 mpg on the freeway. I used a Trans-Dapt adapter and blended the transition by hand. I also used a 2bbl phenolic spacer from Canton Racing Products. I could never get the Rochester to operate as efficiently as the Holley 2bbl, no matter what I tried.
09-04-2014, 04:11 PM | #14 |
Moderator
Anyone use a GM Rochester 2BBL? I still have my complete setup sitting around from my 71 Chevy 350 that I upgraded.
02-28-2019, 11:52 AM | #15 |
Does anyone have an update on this thread? I cannot afford to do the complete change to headers and intake but need to do something my one barrel is trash. If I go to transport adapter which carb do I use?
03-01-2019, 10:53 PM | #16 |
Bump
03-01-2019, 11:47 PM | #17 |
Bump doesn't tell us much.
Ect isn't a word or abbreviation just for general info. illiteracy is a bad thing. Try etc. Ggenerally from GM the carb size is an indication of engine design; or rather compression and cam selection. A laeger carb may help performance but I'd rebuild the monojet. |
03-02-2019, 01:37 AM | #18 | |
And when you decide to play the role of grammar police on an internet forum, make sure you proof your own post before you submit it.
1965 Chevy C10 Stepside Shortbed--2012 370Z Base Gun Metallic--2020 Chevy Silverado RST Crew Cab |
03-02-2019, 09:00 AM | #19 | |
Check The Champ, Demonstrator
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
10-30-2020, 09:24 AM | #20 | |
I currently have a 292, stock in my truck. I have a set of Langstons headers I would like to install. I'm looking for a Clifford intake and they are sold out, if I don't run across one by spring I plan on adapting a 2 barrel holly to my original intake. My question to you is, I'm only going to drive this in the summer so do you think I need to add heat to the intake? It will probably never run below 55 degrees. |
11-01-2020, 01:40 AM | #21 |
I Did Stromberg to 525 Holly so Much Better Pulls Harder And better gas mileage
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
