02-25-2014, 11:56 AM | #1 |
Door check repair?
The door check on my driver's door is broken (one of the friction pieces fell off). Is there any way to repair it without removing the door or replacing the hinge? TIA.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-25-2014, 03:07 PM | #2 |
Re: Door check repair?
What's a "door check"? Is that the thin strip that slides inside the hinge?
Daniel 68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594 Romans 10:13 Everyone who calls on the name of the Lord will be saved. |
02-25-2014, 04:10 PM | #3 |
Yes. I'm not sure what the proper term should be, that's just what I've always called it.
02-25-2014, 04:27 PM | #4 |
Mine hasn't worked for a while. The wife complains about it all the time.
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
02-25-2014, 04:28 PM | #5 |
It's alsways something.....
"door check" is what I call it too, Rob. I have the same issue and tuning in to see what happens
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
02-25-2014, 07:04 PM | #6 |
Cool Truck
curious about this myself
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
02-25-2014, 07:15 PM | #7 |
I searched this site a couple weeks ago for the same thing and didn't have much luck finding any answers. Some people were calling them a "wind check" but I'm not sure what the correct term would be called. I ended up buying a new upper hinge from a board member to replace mine but I also have the doors off which makes it easy to access right now. I wish someone would repop these without having to buy the whole hinge since they seem to fail quite often.
1949 Chevy 3100 Five Window 1964 Chevy C10 Lambrecht Auction project 1967 Chevy SWB K10 1967 GMC K15 Project Build thread- http://67-72chevytrucks.com/vboard/s...72#post6502772 1968 Chevy Anniversary K10 1991 K5 4" Lift 35's (the wife's toy) |
02-25-2014, 07:28 PM | #8 |
Here's a NOS retaining arm on Ebay.
http://www.ebay.com/itm/NOS-1967-68-...97ef8a&vxp=mtr I don't know if you'd be able to drive the pin out of the hinge with the door on though. I read some guys were either flipping over the friction pad on their old ones or even cutting a small piece of an old brake pad to replace it.
02-25-2014, 07:43 PM | #9 |
I have repaired the door stops with the doors on the truck. Driving the pin out is not too bad. If you need to replace the strap, make sure you get one that matches your old one as there are differences.
I make pads from brake material and glue them into the holders with 3M trim adhesive. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
02-25-2014, 08:15 PM | #10 |
My door check/stop didn't break, but one of the pads fell out. Here's a picture of the hinge and the piece that is missing. I'm assuming I have to remove the pin, to remove the stop, in order to replace the friction pads. I have an extra hinge that I tried driving the pin out with my press...it wouldn't move...
02-25-2014, 09:55 PM | #11 |
I had a couple of hinges that the door check strap had broken on and some others that the pins had broken. So out of the 8 to 10 sets of hinges I have I still ended up with some new ones for the first set of uppers on the first 70 that I am doing. After the check had come apart there was not enough parts left to put it back together after the other hinges gave up their goods too. I found it easier to just give in and order a pair of new uppers.
02-26-2014, 10:27 AM | #12 |
That pin comes out pretty easy with a long thin punch if not rusted solid. Usually the passenger doors at pick a parts have decent pads. Might need to take apart several to get a few good pads.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
02-27-2014, 10:58 AM | #13 |
Pics of the homemade ones?
02-27-2014, 11:03 AM | #14 |
Bruce covered it.
http://67-72chevytrucks.com/vboard/s...=318544&page=5
Matt Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784 My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924 My philosophy on tires is the same as cigarettes. "smoke them if you got them" HAPPILY DIVORCED! |
02-27-2014, 11:15 AM | #15 |
Perfect, thanks!
09-12-2014, 10:33 PM | #16 |
Carpe manana
Door friction pads were still available recently from GM...I ordered/received sets last year
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
