02-25-2014, 01:31 PM | #1 |
Vendors...I want to buy some column items...please look!!!
I want everything to do with the shift indicator except the actual housing...I will use mine.
I want the fiber optic light, bulb housing, indicator, indicator "glass" insert, and whatever else that might go along with that stuff. Thanks |
02-25-2014, 02:45 PM | #2 |
Always on the hunt...
Re: Vendors...I want to buy some column items...please look!!!
What year is your column and is it for a tilt or standard non-tilt, your comment regarding fibre optic is saying A.T. non-tilt but then bulb housing could be saying its a A.T. tilt? The shift indicator parts are 67-70 and 71-72 specific on the A.T. non-tilt columns. Mel
02-25-2014, 04:01 PM | #3 |
71 chevy. non-tilt. automatic. no bulb housing i guess. I just saw that in the book. Thanks
02-27-2014, 07:01 PM | #4 |
Bump...Anyone???
02-28-2014, 01:28 AM | #5 | |
New 71-72 shift indicator fiber optic cable/$20. New 71-72 shift indicator dial housing/$8. New 71-72 shift indicator dial lens/$10. New 71-72 shift indicator pointer/$10. New 67-72 column to firewall boot/$12. New 67-72 column to dash grommet/$6. Used 67-72 fiber optic lamp socket and bulb/$5. GM NOS 67-72 fiber optic lamp socket/$25. |
02-28-2014, 10:48 AM | #6 | |
1-fiber cable 2- dial lense for non-tilt 3- pointer for non-tilt 4-both seals Question- does non-tilt use lamp socket?? I thought that was for tilt. Any bearings. Need lower kit and upper. |
02-28-2014, 10:29 PM | #7 |
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear Last edited by leddzepp; 02-28-2014 at 11:17 PM. |
02-28-2014, 11:45 PM | #8 | |
GM 67-72 non-tilt column upper bearing/$28. GM 67-72 non-tilt column lower bearing kit/$46. |
03-02-2014, 05:39 PM | #9 |
Working on getting a few other members parts ready for shipping today, what were your intensions on the above offered parts? Please reply, Mel.
