Old 02-25-2014, 02:31 PM   #1
Kaotik Kustumz
Kaotik Kustumz's Avatar
Camaro gauges in '86 LWB
Anybody got any DETAILED pics and information bout putting the Iroc-Z gauges in the gauge cluster and making them work?
Any info would be greatly helpful
KAOTIK Kustumz
1984 Chevy 1 Ton Crew Cab Dually "Western Hauler"454, th400, (6.0, 4l80e Swap Coming Soon)(5/7 Drop Coming Soon) (ON HOLD FOR NOW)
1986 Chevy 1/2 Ton LWB Silverado350, 700r4, (5.3, 4l60e Swap Coming Soon)(4/6 Drop)
Kaotik Kustumz is offline   Reply With Quote
Old 02-25-2014, 03:05 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Camaro gauges in '86 LWB
There's a thread somewhere done by 3ric that has exactly that but I'm having trouble finding it.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 02-25-2014, 03:21 PM   #3
INSIDIOUS '86
http://67-72chevytrucks.com/vboard/s...d.php?t=276995
Old 02-26-2014, 12:00 AM   #4
Kaotik Kustumz
Originally Posted by INSIDIOUS '86 View Post
Thanx bro for the link....
How hard is it to install the speedo?
KAOTIK Kustumz
Old 02-26-2014, 12:13 AM   #5
INSIDIOUS '86
Wasn't any harder than the tach for me. Needs the same clearance mods though as the tach. I don't know how many photos are left in the thread though. Going to be a couple weeks till I do another one myself
Old 02-26-2014, 12:55 AM   #6
Kaotik Kustumz
It just hooks up directly to the speedo cable don't it?
Then just mount it in the cluster....
KAOTIK Kustumz
Old 02-26-2014, 02:46 AM   #7
INSIDIOUS '86
Pretty much. Once you have everything apart the only trick part is wiring really.
Old 02-27-2014, 10:13 PM   #8
wraprail
wraprail's Avatar
The 2nd gen camaro gauges work pretty good too. Speedo is a bolt in, tach requires a little clearance
wraprail is offline   Reply With Quote
Old 02-28-2014, 07:45 AM   #9
Kaotik Kustumz
Ok kewl....
How hard is the wiring and could you show how to hook up the fuel gauge once it's put in place with the tach?
What wire hooks up at what location?
KAOTIK Kustumz
Old 03-01-2014, 03:33 PM   #10
Kaotik Kustumz
Could somebody help me out with the wiring of these gauges?
KAOTIK Kustumz
Old 03-02-2014, 04:57 PM   #11
INSIDIOUS '86
Are the pictures gone in that thread?
Old 03-02-2014, 07:18 PM   #12
Kaotik Kustumz
No they're there.... Just need more detail on how to hook up the fuel gauge....
What wire goes where and how to hook fuel gauge up into the factory wiring
KAOTIK Kustumz
Old 03-02-2014, 10:58 PM   #13
INSIDIOUS '86
Do you have the gauge in the tach or off to the left?
What I did was take some extra nuts that hold the circuit board on and extended wire from the back of the fuel gauge pins and made studs on the factory clustp backing were the factory fuel gauge studs pressed in.
Does that make any sense? I can try and get one pictures up but I'm not sure when.
Old 03-02-2014, 11:27 PM   #14
Kaotik Kustumz
Ya I'm gonna be running the fuel gauge in the tach and run the camaro speedo also....
All the other gauges on the left are gonna get swapped out with after market gauges also....
This is the way I'm gonna run tach and speedo...
With these gauges on the left side...
KAOTIK Kustumz
