Old 02-25-2014, 05:00 PM   #1
rideblue00
rideblue00's Avatar
60-63 frt bumpr fit 64-66?
Will a 60-63 front bumper fit a 64-66. Im interested in it for my 66.
rideblue00 is offline   Reply With Quote
Old 02-25-2014, 05:25 PM   #2
forestb
forestb's Avatar
Re: 60-63 frt bumpr fit 64-66?
I think so but I would wait for some other replies.
forestb is offline   Reply With Quote
Old 02-25-2014, 05:26 PM   #3
1963c-10
1963c-10's Avatar
The 63 bumper will. The 60-62 has a different frame, so different mounting location.
Also....the 60-66 used the same rear bumper on stepsides...just different mounts
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 02-25-2014, 07:40 PM   #4
rideblue00
rideblue00's Avatar
Ok thanks guys
Old 02-26-2014, 02:07 AM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I confirm the post of 1963c-10.
60-62 are different than 63-66.
66 C20 Service Truck:
Old 02-26-2014, 02:12 AM   #6
LostMy65
LostMy65's Avatar
The confusion about the 63 is the transition from X-Frame to Ladder Frame, and the wrap around front window.
60-62 used X-Frame.
63-66 used Ladder Frame.
60-63 used the wrap around window.
64-66 did not.
So 63 is an odd transitional year.
Old 02-26-2014, 03:42 AM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
In reality a 60-62 bumper should also fit just fine on a 63-66. The only difference I'm aware of is the vertical distance between the inboard bumper bolt holes being closer together on the earlier bumpers. If you didn't mind drilling new holes, the rest of the bumpers should be the same. If you installed bumper guards over the inboard mounting holes, the extra holes would be hidden behind the guards.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 02-26-2014, 04:03 AM   #8
LostMy65
LostMy65's Avatar
Good point.
