Old 02-25-2014, 07:01 PM   #1
groundbound64
Spindle Problem
I installed a set of CPP drop spindles (bought thru Borthers Truck) on my truck recently and one side (rf) sits higher up on the Ball Joint than the other. It's about 1/2" difference. You can't use the washer on R\F side. Here's the pics of each side. To Me the L/F looks correct with having more threads showing and sitting lower on the spindle. Brothers did warrenty me a new spindle (arrived today) but seems to be the same. I was curious if anyone else has had same problem??
64 C10 Stepside 350/4psd Driver/Project on air.
Dom bags, Dual Viair and AccuAir
08 Ford F150 Limited- F-word ! Daily Driver
.......................____
..........._______l/ \____
...........|_/(0)\_ll____/(0)_l.
groundbound64 is offline   Reply With Quote
Old 02-25-2014, 07:09 PM   #2
Slow Build
Slow Build's Avatar
Re: Spindle Problem
Look to me like the left one is the problem. The cotter pin is way above the castle nut. Which spindle did they replace?
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 02-25-2014, 07:14 PM   #3
firemanjimtfd
firemanjimtfd's Avatar
Re: Spindle Problem
I just installed CPP drop spindles last week and they both fit like the top photo . Dust shield just barely touching the bottom A arm. Is there a difference in your ball joints ?
firemanjimtfd is offline   Reply With Quote
Old 02-25-2014, 09:31 PM   #4
groundbound64
Re: Spindle Problem
They replaced the R/F. The ball joints are new 73-87 BJ. they are the same. Here's another pic of spindle. I asked if they could compare with known good spindles but I don't know if they did. Here's two other pics. I took these for guy @brothers.. anted to show using my finger difference.. I think one bore was machined wrong.
Old 02-25-2014, 10:01 PM   #5
firemanjimtfd
Re: Spindle Problem
Or is one of your index fingers is bigger than the other LOL . Is it a tapered hole or can you drill out and fix. As expensive as they are they better send you another one. My drop spindles were for the stock 66 ball joints.
Old 02-26-2014, 02:43 AM   #6
Captainfab
60-66 Nut
Re: Spindle Problem
I agree
I would say that the left spindle, lower hole was reamed too deep.
Old 02-26-2014, 07:49 AM   #7
tincan1966
tincan1966's Avatar
Re: Spindle Problem
I agree - the Left side is the concern. The cotter pin should go thru the castellated part of the nut, not that far above it.
I'd send CPP those pics and they should see the problem, too.
tincan1966 is offline   Reply With Quote
