1963 SWB Fleetside bed bolt length needed
Need the length of the bed mounting bolts for a 63 short fleetside truck. Im a stepside guy and i know the fleetsides are different. Picking up the new 63 Saturday and need to get the bed bolted back down to transport. Just need the length and size....thanks in advance.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Re: 1963 SWB Fleetside bed bolt length needed
I'm pretty sure they are probably 7/16 or 3/8 diameter. Ive looked through the FAQ's with no luck. Found a ton on the 67-72 board, but I know some of those beds were steel also.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 02-25-2014 at 08:16 PM. |
![]() ![]() Join Date: Apr 2012
This isn't going to help much but these are what they look like. These were from my 63 longbed. If no one answers I will pull one off tomorrow and measure.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
I just need to pick up something to get it home (2hr drive). Won't be permanent, just a couple of carriage bolts I can pick up from home depot for the transport. I'll get the proper hardware when I get around to restoring it.
And thanks for the help.
A couple of 4 inch will work. Or you can get a couple of 5 inch to make sure
66 shorty ![]() |
ok, thanks. i'll get some 3/8" x 4.5" then
