Old 02-25-2014, 11:43 PM   #1
69Rumbler
69Rumbler's Avatar
Better ride ??
I got a 69 c20 with leaf springs .. I'm looking to get a better smoother ride what are some thing that be done? I replaced the shocks and I'm going to do the leaf springs next .
Thanks !
1969 C20 CUSTOM "RUMBLEr"
69Rumbler is offline   Reply With Quote
Old 02-25-2014, 11:53 PM   #2
Sicklajoie
The Niner
Sicklajoie's Avatar
Re: Better ride ??
It's an expensive upgrade, but I've got Michelin tires. The soft sidewalls make for a better ride.
You're kind of stuck with a leaf spring truck. Coil spring setups do ride better. Leaf spring trucks ride like trucks... lol
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 02-26-2014, 12:07 AM   #3
leddzepp
Moderator
leddzepp's Avatar
Re: Better ride ??
Throw a few bags of concrete in the back, it will ride a lot smoother.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 02-26-2014, 12:25 AM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Better ride ??
Or just get used to it... It's an old truck. They weren't made to "ride nice."
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-26-2014, 12:32 AM   #5
69Rumbler
69Rumbler's Avatar
Re: Better ride ??
Yea that was my thinking it's a 69 it should ride like one haha
Old 02-26-2014, 11:39 AM   #6
Re: Better ride ??
I'd leave as is and have a great truck that can haul anything. While beboppin' around do as Scott said and toss a few bags of sand across the back of the bed. You might need the sand sometime and you'll hook up better on those light to light drag races (or slight grade in loose gravel
Old 02-26-2014, 11:41 AM   #7
69Rumbler
69Rumbler's Avatar
Re: Better ride ??
I had some one offer me a set of tailing arms ? Any thoughts
Old 02-26-2014, 11:42 AM   #8
Sicklajoie
The Niner
Sicklajoie's Avatar
Re: Better ride ??
The crossmember is different for trailing arms vs. leaf springs.
Old 02-26-2014, 11:44 AM   #9
69Rumbler
69Rumbler's Avatar
Re: Better ride ??
Sounds like it would be a pain , I'm sticking with leaf just going to get some new leafs with a 3" drop
Old 02-26-2014, 12:23 PM   #10
Sicklajoie
The Niner
Sicklajoie's Avatar
Re: Better ride ??
A 3" drop?? Why would you do that??
Old 02-26-2014, 12:39 PM   #11
69Rumbler
69Rumbler's Avatar
Re: Better ride ??
To level it out .. Not trying to drop it just want it sitting straight
Old 02-26-2014, 01:03 PM   #12
Sicklajoie
The Niner
Sicklajoie's Avatar
Re: Better ride ??
That seems like a lot, I think mine has an 1" or 1.5" rake.
Old 02-26-2014, 02:57 PM   #13
67 chevelle
67 chevelle's Avatar
Re: Better ride ??
sway bars , change all the bushings in the front sway bar , if you do not have a rear sway bar , install one , your handling , corning , and all around drive ability will DRASTICALLY improve .
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 02-26-2014, 04:05 PM   #14
67 chevelle
Re: Better ride ??
Also changing to a newer , quicker ratio steering box , will greatly improve road feel , make sure it is centered correctly , they are tighter in the centered position , for about 3/4 turns each way , the one I used was a 78 model year
Old 02-26-2014, 06:02 PM   #15
69Rumbler
69Rumbler's Avatar
Re: Better ride ??
That will be next thing I do change the bushings of my sway bars thanks
Old 02-27-2014, 08:06 PM   #16
'68 Newtricks
'68 Newtricks's Avatar
Re: Better ride ??
Opps
'68 Newtricks is offline   Reply With Quote
Old 02-27-2014, 08:14 PM   #17
'68 Newtricks
Re: Better ride ??
I wasn't sure if I should clutter up the thread with my offer on the trailing arms, but yes that was me. I'm local and I offered a running long bed chassis from the firewall back, with Eaton axle. Figured if he had everything, it's just a bolt on ordeal. (Except removing rivets, but at least he only has to remove the bed) Was only asking scrap value (~$100 I guess) since I'm just looking to get it off my lawn. Heck, you can have the bed with it. It's has pretty nice fenders too, though inside is crap.
I'm swapping everything over to a short bed frame that's been sandblasted blah blah blah. Rather see someone use it than it go to China.
