Extreme Oversteer
HI all, I need the boards wisdom on this one, I have replaced almost everything on my 68, the front end has been rebuilt and I added a saw bar and power steering. Now I know modern power steering adds more pressure or something to the steering wheel at higher speeds and the tires turn less as you turn the wheel. I think its called variable speed, anyway I installed power steering along with a new steering box but at 65 I can twitch and change lanes. Any thoughts on how to change this. I have about one and a half turns from center to lock. The truck can be a bit scary to drive.
Re: Extreme Oversteer
Sounds like you may have a high performance style steering box. I think mine has about 3 turns to center.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
I think jjzepplin has the answer. I recall 3 turns as being right.
Another thought is .. there is a screen /fitting on the gear box on the inlet where the pressure line attaches". It is behind the fitting and requires removal of the fitting to find it. If that screen wasn't there that may affect the gear box also. Easy to check anyway.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Will do, I will check it. What do they make the high performance ones for, 4 wheeling? anything over 40 and you almost roll when you even think about changing lanes.
Also, thank you. |
CAN'T FIX NOTHIN
I got a rebuilt power steering gear box from advance auto parts paid high money for it and mine is fine going straight if you go around a curve it has slack and you have to fight it , I've drove it several years hate to think I threw away $300 bucks but that's what I di I orderedc a new one from cpp its on my kitchen table soon as its warm enough I'm gonna pitch the advance one
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC Last edited by 19673ontree; 02-26-2014 at 06:16 PM. |
Sounds a lot like a castor issue,, Calling Bemer Doc, Your input please?
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
Someone call me? LOL!! Did you have it aligned after adding the box? You said 1.5 turns from center to lock so thats still 3 turns from lock to lock. Six of one...half dozen of another.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
I did, I replaced the wheel bearings, outer tie rod ends, idler arm, pitman arm and box, spring, shocks and then did new tires followed by an alignment.
Did you get a copy of the spec sheet?
I was dumb, I didn't.
Well you're gonna have to get another one. Any of the angles can cause it to be twitchy. Some more than others. Excessive toe out, Caster too shallow or too much positive Camber. Toe is the worst offender. Caster would make it wander..not so much twitchy. What are your tire pressures set at? Double check the pressures to make sure they aren't jacked.
Will do, thanks.
#13 |
I bought a set of 4 used tires once. I put 2 on the front of both my cars. Not long afterwards both cars started getting twitchy and tring to change lanes, both left and right. I got pulled for drunk driving about 4 times and I don't drink at all!
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#14 |
Tell them to take out all the shims and start over. 1/16" per side on toe (1/8" total). As much negative camber and as much postive caster as possible. Here is a link to my last alignment and what I consider to be the ONLY way to align a shimmed vehicle of the Aligners equipment has this option.
http://67-72chevytrucks.com/vboard/s...d.php?t=582187
#15 |
CAN'T FIX NOTHIN
I know that you know EXACTLY what you are doing bmerdoc and I would gladly pay for someone to align a front end correctly but here in the sticks where I live their just isnt anyone that can or will do it , they are smart when you get a front end aligned they set it so the tires wear out on the inside LOL I figured out a hillbilly alignment technique I use with no problem have done mine myself since the 80s , and no im not gonna explain it cause you will just laugh at me LOL ,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
#16 | |
Twitchy and oversteer are not the same thing....
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#17 | |
#18 |
the boat guy
It took the alignment shop 2 hours to align my truck the way I wanted it (as much camber without the mod). It wasn't too long after it started getting twitchy, the shims fell out... took them an hour to fix that side.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
#19 |
#20 |
Thanks for the specs and the video! Let me ammend my title statement.
Basically, I barely have to move the wheel at anything over say 20-30mph to change lanes, barely is 1/4 inch. It's like having powersteering with far too much assist. I think it is the alignment, they all swear they are doing it correct because of the big computer but I am going to give them the specs that need to be hand entered. When they search for 68 it sometimes doesn't even come up and i think they go with a 73, not sure. Anyway thanks all! |
#21 |
How about this. If you need it, PM me and I'll give you my phone number. I can talk to you more about it or talk with the shop and talk them through it.
#22 |
Thank you, I will find the shop and then shoot you a PM. (I don't want to use the last shop again.) Thank you! I will PM you soon.
#23 |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
I don't know if this is your issue or not, but you can check to see if your frame is dimpled for the integral power steering gear. I know that none of the 67s were. People tend to just shim the gear out to bolt it squarely on the frame. Problem with this solution is when driving strait, you are not in the center of your gear, you are actualy turning right slightly. Not being in the center of travel in your gear leads to the same issues that you are talking about. In this thread you state you have a 68 witch I would think that this explination wouldn't apply, but hey it's worth a mention, just because I have seen stranger things. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#24 |
Registered Cruiser
I think BMRDOC nailed it when he mentioned the toe. A little toe-out will make your steering reaction very "darty" lol It looks silly typed out, but the guy who mentored me on chassis setup called it that.
"darty"meaning it would want to dart one way or the other with very little steering wheel input. It's pretty easy to rig a bar to check your own toe. Front end alignment isn't rocket science, although most front end shops would like you to think that. Most of the difficulty comes with lowered vehicles when you are at the extremes of your adjustments due to the non stock A-arm geometry.
I intend to live forever. So far, so good. |
#25 |
That's the word, darty. Definitely. I do have the dimple. I remember being grateful not having to , "make one".
