Old 02-26-2014, 02:17 PM   #1
kevmac
kevmac's Avatar
Coil relocation
Where is everyone relocating the coils on 67-72? Looking for ideas.
Thanx for any ideas.
kevmac is offline   Reply With Quote
Old 02-26-2014, 03:08 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Coil relocation
mine are in stock location but long term plans are to move them to back side of intake/heads out of sight.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-26-2014, 04:00 PM   #3
fastpace
Re: Coil relocation
I saw someone else had relocated them to the inside of the frame rail and I'm planning on doing the same.
1972 C10 LWB Highlander Dark Olive/White - Work in progress 5.3/6L80e, Accuair e-level, Porterbuilt Stage 1 front and Stage 2 rear, Wilwood 14"F 13"R, Vintage Wheel Works V40 18x8/18x11, and more... Build Thread
fastpace is offline   Reply With Quote
Old 02-26-2014, 04:23 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Coil relocation
There is a commonly available relocation "panel" that holds 4 coils on a angle-iron looking peice,and bolts it to an unused stud-boss in the back of the heads. You need a lot of firewall clearance for that tho. Relocation TO the firewall is also a cool option, but just requires a little planning. The same type of bracket/panel mentioned can bolt to the firewall, only downside being that the firewall is stationary, and the engine is not (i.e sizing the length of the wires is important so you don't tug on them under load)
If you just don't want to see them, I would consider one of two options.
1. just use an engine cover. You don't really see the coils much under it, unless you look from an extreme-side angle.
2. use the fake-valvecover coil covers. They look like an old high-lift valvecover, just like you might see on an sbc/bbc...except the added height fits OVER the old valvecover and hides the coil packs.
Sadly, this is a beautiful motor with nice parts....and then they slapped the MAF right on the TB....go figure.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-26-2014, 05:37 PM   #5
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: Coil relocation
I made brackets to mount them to the one of the engine mount bolts.
I am going to be running different coils this year, so I'm selling these brackets and/or coils if anyone wants them. They probably won't work on an N/A setup though...
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 02-27-2014, 08:19 PM   #6
kevmac
kevmac's Avatar
Re: Coil relocation
I'd take if I thought they'd fit not much room with headers.
Old 02-28-2014, 06:48 PM   #7
69trk
69trk's Avatar
Re: Coil relocation
pm sent
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 03-30-2014, 09:55 PM   #8
Wasted Income
Boosted Member
Re: Coil relocation
I ended up rethinking my coil relocation.
Turbo diesel
Old 03-31-2014, 01:52 AM   #9
kevmac
kevmac's Avatar
Re: Coil relocation
Not a bad idea, driver side?
Old 03-31-2014, 02:15 AM   #10
BigDan3131
BigDan3131's Avatar
Re: Coil relocation
Wasted do you not drive it in the rain? or worry about water on the road splashing up on them? You could just make up a shield to protect them from that.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 03-31-2014, 08:25 AM   #11
68Stepbed
68Stepbed's Avatar
Re: Coil relocation
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 03-31-2014, 09:42 AM   #12
Wasted Income
Boosted Member
Re: Coil relocation
Same location on that side.
They will be fine. I had them down low last year and drove it in the rain with zero issues.
Turbo diesel
Old 03-31-2014, 12:51 PM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Coil relocation
They are pretty weather resistant, the harness leads to the coil are the weak link. Driven with no hood for a while, so I'm pretty confident in the LS's weatherproofing hehe.
Old 03-31-2014, 03:17 PM   #14
kevmac
kevmac's Avatar
Re: Coil relocation
Originally Posted by 68Stepbed View Post
Matt, looking good
Old 03-31-2014, 03:36 PM   #15
K10 STEPSIDE
K10 STEPSIDE's Avatar
Re: Coil relocation
This is something different, but it only works on truck intakes. Now just need some better looking valve covers
_______________________________________________
A project can be finished, but a car is never done.
1967 chevy K10 step
2002 chevy Impala
Latest Project http://67-72chevytrucks.com/vboard/s...d.php?t=605308
K10 STEPSIDE is offline   Reply With Quote
Old 03-31-2014, 04:45 PM   #16
solidaxel
solidaxel's Avatar
Re: Coil relocation
Tell me about the high tension wires, where did you get them, and where did you mount the brackets on the plenum?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-31-2014, 05:24 PM   #17
K10 STEPSIDE
Re: Coil relocation
The wires are a cut your own kit from taylor that I got from a local store, but the coil plugs are special for ls engines so I ordered them from summit (part# 46069) to make My own kit.
the brackets that hold the coils make a 90 degree turn at the bottom and the bolt down with the same bolts as the fuel rail.
1967 chevy K10 step
2002 chevy Impala
Old 03-31-2014, 08:10 PM   #18
Andy4639
Old member
Andy4639's Avatar
Talking Re: Coil relocation
That's pretty slick. I like it. The motor cover covers them well also. Two
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-31-2014, 08:18 PM   #19
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Coil relocation
A quick note on Taylor wires, if you use them (which is fine, I have some now), but they are sensitive to being pulled out by the wire. Even when grabbing by the boot, be careful that it doesn't seperate from the wire. This is an issue on some of the 9.8mm and 8.5mm wires with the silicon body. IF you pull it by the wire, it stretches and thins out, enough to slip out of the boot. Some high temp glue or silicon might help, haven't tried it.
The plug wires with the firmer rubber or reinforced silicon aren't as prone to it.
Old 03-31-2014, 09:40 PM   #20
littlevictories
Re: Coil relocation
man i just did that on an MSD wire. yankin on it all sideways when i was too tired to think clearly. sucks to roast a $60 wire set because dumb.
littlevictories is offline   Reply With Quote
Old 03-31-2014, 10:51 PM   #21
K10 STEPSIDE
Re: Coil relocation
Better to hear about it than to find out first hand. I can see how it can happen with them though. The casing does slide around and they can become very tight on the plug.
1967 chevy K10 step
2002 chevy Impala
Old 04-01-2014, 10:06 AM   #22
Wasted Income
Boosted Member
Re: Coil relocation
K10 Stepside, that is slick. I like it.
As for custom length plug wires, I measured what I needed, and got some custom length Firecore 50 wires.
Turbo diesel
Old 04-01-2014, 10:43 AM   #23
solidaxel
solidaxel's Avatar
Re: Coil relocation
Will some dielectric grease on the plug/boot help with removal?
LS 3 4L70E
Old 04-01-2014, 12:59 PM   #24
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Coil relocation
It'll never hurt. The problem seems to be between the boot and the wire, since the boot itself is only slip-fit on most plug wires.
Old 04-01-2014, 01:27 PM   #25
Wasted Income
Boosted Member
Re: Coil relocation
MSD's are horrible about coming apart, too.
The Firecore wires come highly recommended by lots of racers who are pulling the boost off of the plugs often between rounds. They bond the boot to the wire, and it is supposed to help keep them from pulling the terminal ends off.
https://www.customwiresets.com/home.php?cat=3
Turbo diesel
