Manifold Vacuum
I'm only getting 12lbs of vacuum at the manifold. Shouldn't it be higher? I have adjusted the idle screws a few times but I can't get it above 12.
-Jason USN Retired |
![]() Join Date: Oct 2011
Re: Manifold Vacuum
...thats not overly high but there might be a little more at work here.
When you view the vacuum gauge is it steady? (here is a great link to get started...scroll down the page to readings...very interesting and see how it relates to your condition...AND, note scenario 10 on the reading reference from the website.) http://www.secondchancegarage.com/public/186.cfm Next, how is your timing?....note where it is right now...and try both advancing it and retarding it. Both of these efforts will usually reveal a change in both vacuum and needle behavior. Also, plug the vacuum advance and recheck the readings) The most important thing is to get the needle steady. What is your engine rpm when you are checking. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
Re: Manifold Vacuum
Hi, it probably should be a little higher, ( 17-22) leave the gage hooked up and move the timing back and watch the gage. see how it runs then...Does it have a hot cam in it?( a lot of duration) that would make it lower too...OOPS, Coley beat me to it....
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. Last edited by hamjet; 02-26-2014 at 03:08 PM. |
#4 | |
Re: Manifold Vacuum
Re: Manifold Vacuum
...Ok...something in that is not quite correct Jason.
The vacuum port on the carb should NOT be providing any vacuum signal at idle....only at higher rpms...definitely not at 750/800 rpm. So it should not be useable for attaching a vacuum gauge to. So something on that vacuum circuit is incorrect. Separately, you need to find a different port ideally for checking this. We don't have any info on your motor or your carb...or any pics. Can you supply us with any of these? Also, was that timing set with the vacuum advance line connected to the distributor? ....or not? Coley
#6 | |
Re: Manifold Vacuum
Motor is a 350 bored over .030. Supposedly rebuilt around 9k miles ago. Has HEI, Double hump 2.02 heads (1492s), Edelbrock RPM intake, and 1406 Edelbrock carb. That is the extent of my knowledge of the engine. I can post up a pic later when I get home if it would help.
#7 | |
Re: Manifold Vacuum
If so, and as Hamjet mentioned....a lower vacuum signal is to be expected. How does the vehicle run? Is it running poorly? or? C.
Re: Manifold Vacuum
Runs like a scalded cat.
![]() My last truck had a lopey cam in it. This one doesn't sound like that. So I'm not really sure what it has in it. Thanks Coley
Re: Manifold Vacuum
Can you bring the idle down under 700 and reset the idle mixture? Should be worth a couple of in. Hg.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
Re: Manifold Vacuum
I can. It seems like if I mess with the idle screws the needle will just flutter until I adjust them back to basically where they are now. The needle is only steady at 12. Once I get the fuel pressure regulator installed tonight. I will try to reset the idle again.
Re: Manifold Vacuum
Check vacuum at the manifold itself where the brakes or transmission vacuum hook up.
Life is too long to go slow... ![]() 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
One of the First
![]() Join Date: Jan 2000
Re: Manifold Vacuum
x2 - Right, that's the place to get the most accurate reading.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
#13 |
Re: Manifold Vacuum
Hugh, when you put in the cam[ you did go with the comp didn't you] did you line the timing marks up? If I remember you were talking about a 268 comp cam and they are know for making real good vac. usually in the 18 inch range.
#14 |
Re: Manifold Vacuum
As BMERDOC said, adjust the idle SPEED screw so that the idle is BELOW 700 rpm. 800 rpm is not a idle rpm. The throttle plates need to be closed far enough so that the mixture screw can control the fuel flowing from the idle port.
![]() When the throttle plates are too far open. you are adding fuel from the transition ports above the idle ports and the idle mixture screws become less able to effectively control the fuel flow. ![]()
'67 GMC 2500, 292, 4spd, AC |
#15 |
Re: Manifold Vacuum
Jim, I haven't changed the cam yet. I am trying to get the engine smoothed out before i make any major modifications.
#16 |
Re: Manifold Vacuum
I did not get a chance to do anything to my truck last night. I got the first phone call from my realtor, that is selling our old house, saying we had a water leak in the attic and there was a hole in the ceiling of the garage. After I figured out what caused that, I got the second call from my buddy (Ford owner, poor guy). He was stuck in the middle of town with a flat on his new F150. The wheel was seized onto the hub and would not come off. Long story short - I was out from the time I got home from work until about 9PM last night. I hope tonight will be a little more productive.
#17 | |
Re: Manifold Vacuum
I bought a pressure regulator yesterday with every intention of installing it last night but it didn't happen. I hope when I get it installed tonight and lower the line pressure I will be able to lower the idle speed then adjust the idle mixture screws again and get the vacuum up.
#18 |
Re: Manifold Vacuum
Fwiw 12 in of vacuum is plenty good as long as your power brakes work (if you have them).
Best to set your carb with the vac advance plugged in. THat way you can lower your idle as much as possible. You can buy vacuum tees at the parts store. A vac source on the carb is exactly the same as on the manifold. Here's a link to some vac tees. Not hard to find. http://shop.advanceautoparts.com/p/d...354/22147871-p |
#19 |
Re: Manifold Vacuum
Geezer, my brakes work fine. I was just concerned that lower vacuum could affect the overall performance of the engine.
#20 |
Re: Manifold Vacuum
I have a fairly stout 355 crate motor, and it has a moderate high perf cam. Best I can get is 15" of vacuum at 700 rpm with timing at 14---thats what it seems to like best. With a little more cam I could easily see 12" being normal.
Just FYI, if you get below about 10" at cruise, you will want different rod springs in the carb or you will be running rich all the time.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
#21 |
Re: Manifold Vacuum
I have a feeling once I stop water-boarding my carb my vacuum will improve.
#22 | |
Re: Manifold Vacuum
I have read that the higher feed pressure will overwhelm the float needle and push extra fuel, creating a rich condition, which can cause you to increase the idle setting and lean out the idle screws to get it all to work. That can through you way out of whack and make you chase your tail.
#23 |
Parts and more parts
Re: Manifold Vacuum
Things that I would do to get this adjusted. 1. get your fuel pressure where you want it. 2. check your cylinders for compression---to see if you have a valve sticking issue. 3. Adjust the carb idle settings by using a vacuum gauge to get the optimum setting for your combination.
However I run about 12 to 13 on my stroker engine, but I have a fairly active Comp cam setup on mine and the idle indicates a fair lope.
Frank |
#24 |
Re: Manifold Vacuum
I have already checked the compression on the engine. The cylinders average 150lbs. All within the acceptable differences of each other.
It would be easier if I knew what was inside the engine. I would know better what to expect from it when trying to tune it.
#25 |
One of the First
Re: Manifold Vacuum
If you need to check the condition of cylinders and valves. You can do a leak down test with a leak down tester. That will let you know if you have a problem or you can eliminate the combustiom chambers.
I had to troubleshoot some some issues with my motor: mild stumble, hard start... I used a direct manifold vacumn source. Eliminated / plugged of brake booster. My issues ending up being late timing and a lean running carb. Being a novice mechanic, The problem I had with testing from carb was knowing which was ported or manifold vacumn and my readings seamed to be always erratic.
