Old 02-26-2014, 04:26 PM   #1
grs
Choke rod to short.
I was going to put a Mr. Gasket carb adapter on my truck. After I bought it I noticed the choke rod on the divorced choke will be 3/4th of an inch to short, because the adapter raises the carb up 3/4th of an inch. Does any one make a choke that has a longer rod?
grs is offline   Reply With Quote
Old 02-26-2014, 05:42 PM   #2
ray_mcavoy
Re: Choke rod to short.
There are some replacement divorced choke rods available for some stock applications. But I don't think I've ever seen a longer one available for use with a carb spacer/adapter.
In those cases, I usually just bend my own from a piece of 1/8" welding rod. The hardest part is drilling a hole for a tiny cotter pin or cutting a groove for a small retainer clip to hold the rod on the carburetor end.
ray_mcavoy is offline   Reply With Quote
Old 02-26-2014, 07:06 PM   #3
grs
How does the rod fit into the spring?
Old 02-26-2014, 07:12 PM   #4
ray_mcavoy
They usually have a 90 degree bend at the lower end of the rod and the bent part just slides into a rolled loop that's formed on the end of the spring.
The sheetmetal cover over the spring is primarily there to hold in heat but it also serves as a retainer to keep the lower end of the rod from sliding sideways out of the rolled end of the spring.
Old 02-26-2014, 07:56 PM   #5
grs
Maybe I could use a metal coat hanger.
Old 02-27-2014, 08:33 AM   #6
ljackson
ljackson's Avatar
I have recently been getting some info from the board about chokes and choke operation. I recall reading that several folks use a spacer to get heat out of the carb in the summer. Not what is needed in the winter. It’s probably not an issue where you live. Just a thought. This is some info related to a Rochester 2G.
http://67-72chevytrucks.com/vboard/s...d.php?t=613559
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 02-27-2014, 01:28 PM   #7
luvbowties
luvbowties's Avatar
Thumbs up Re: Choke rod to short.
I've used a tiny nut--too small for the rod-end--and forced it to screw just a few turns onto the rod-end, & it holds securely. Easier than drilling the tiny hole or cutting the groove. Looks? If it's yours, & u don't mind, it looks ok.
Sam
luvbowties is offline   Reply With Quote
Old 02-27-2014, 02:26 PM   #8
grs
I lengthened the rod. I used a coat hanger. It was close to the same diameter. My rod has a clip on the end of it. I made it 7/8's of an inch longer.
Old 02-27-2014, 07:32 PM   #9
Rich 5150 69
Rich 5150 69's Avatar
Cool...!
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 02-27-2014, 07:53 PM   #10
ray_mcavoy
Looks great!
I forgot all about that type of clip being used on some choke rods ... that certainly makes things easier.
