Old 02-26-2014, 04:59 PM   #1
Frijolito1988
Gas in oil, car wont start.
Hey guys, so i noticed the truck was leaking alot , though it was tranny fluid , ended up being oil / gas . Took the dipstick out smelled it and sure enough gas.
We just replaced the fuel pump, though maybe it was broken or stuck open or something and replaced the oil / filter.
When the new oil / filter / fuel pump was put in it cranked fine for like 3-5 times/ trys.
Now it makes a hummimg noise, like if we had an electric fuel pump, it just cranks over. It has a fully charged battery, do you guys think the cam lobe might be a problem ?
Frijolito1988 is offline   Reply With Quote
Old 02-26-2014, 05:02 PM   #2
Van1lla Gorill4
Re: Gas in oil, car wont start.
What part of the engine was it leaking from?
Van1lla Gorill4 is offline   Reply With Quote
Old 02-26-2014, 05:14 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Don't go off on the cam lobe tangent. Even if you flattened several of them, the truck would still run.
Old 02-26-2014, 05:43 PM   #4
Frijolito1988
Leaking in the rear down the flywheel
Old 02-26-2014, 05:49 PM   #5
Hugh Mongus
Is the carb allowing too much fuel into the engine?
-Jason
USN Retired
Hugh Mongus is offline   Reply With Quote
Old 04-26-2018, 01:05 AM   #6
faun_cee
did you ever find the problem? im having the same trouble with my truck.
faun_cee is offline   Reply With Quote
