Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 02-26-2014, 05:22 PM   #1
GVDobler
GVDobler's Avatar
What to expect from salvage yard??
If I buy an "engine assembly" out of say a 1999 Tahoe/Suburban
what all would I expect to get with the assembly?
Should I expect a complete engine and the control box for fuel injection?
If I buy the transmission with it, same question, should I expect to get the control box.
Just never dealt with them except for small specific parts.
Jon S
1966 GMC Suburban 305 V6
Las Vegas NV
GVDobler is offline   Reply With Quote
Old 02-26-2014, 07:53 PM   #2
spacedebris
Re: What to expect from salvage yard??
Unfortunately that all depends on the salvage yard in question.
Around me, the salvage yards are not all that reputable and you get whatever they have. The local pick-ur-part charges the same for an engine w/ harness as it does for an engine w/o.
I've found that I do better dealing with the local tow companies. I have contacts at all 3 of the local tow companies and whenever they get a truck they think I may be interested in they give me first crack at it before they take it to the salvage yard. (I pay them the same price as the salvage, take what I want, then scrap the rest) That way I can pull off everything I need without having to figure out what got picked over at the yard.
On the flip side, a buddy of mine in TN says that the local yards in TN and KY seem to be more reliable. Many of them pull the engines complete with harness and controller and sell them as a complete unit rather than parting them out.
Your best bet is to simply ask them.
spacedebris is offline   Reply With Quote
Old 03-19-2014, 09:05 PM   #3
donthekawguy
donthekawguy's Avatar
I just found a 5.3 with 50k on it including trans. and all computers for 2750 in Spokane. They will reflash the computers for another thousand.
66 shorty
donthekawguy is offline   Reply With Quote
Old 03-20-2014, 02:38 AM   #4
66pnl
66pnl's Avatar
1000.00! Is that right or is it 100.00? I think I've seen 150.00 advertised.
66pnl is offline   Reply With Quote
Old 03-20-2014, 02:59 AM   #5
mcmlxix
Collector of Projects
mcmlxix's Avatar
You need to go over in detail what comes with the engine... Intake, throttle body, fuel rail and injectors, exhaust manifolds, waterpump, power steering, alternator, ac compressor, UNCUT engine harness, computer.... Also, depending on the year, you may need the electonic throttle pedal and control box.... if it's a 99 Tahoe it will probably a cable operated throttle body...
The computer can be reprogrammed for $150 or better yet, find a local tuner.
The transmisson also has a contorller and until recently it was built into the main computer. The newer trucks had a seperate EMC (engine management contriler) and TCM (transmission management controler)... Again, if its a 99 its all in one ECM....
Usually you get a 30-90 day warranty on parts.
Rich
1972 K5 Blazer CST Click HERE
Old 03-20-2014, 03:11 AM   #6
mcmlxix
mcmlxix's Avatar
http://lasvegas.craigslist.org/pts/4381608624.html
http://lasvegas.craigslist.org/ptd/4375793258.html
Rich
Old 03-21-2014, 12:38 AM   #7
Captainfab
60-66 Nut
For a grand you could buy everything you need to reflash/tune the PCM yourself.
Old 03-21-2014, 08:13 AM   #8
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
If an LSx is what your looking for, there is a vendor here that will supply a COMPLETE ls motor, with harness and re-flashed PCM for a reasonable price.
here it is, give these guys a call....
http://pacificfabrication.com/engine...s/engines.html
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
