Old 02-26-2014, 06:49 PM   #1
dlturner00
Front Wheel Clearance
Ok, I've got a 69 chassis, 85 front crossmember with McGaughy's 2.5 drop spindles. I was going to use the 85 15" rallyes for temporary rollers but when I put them on I'm so close to the tie rod the wheel weight hits. Back spacing appears to be 4.25. Am I missing something? I did a search and people on here seem to be using the same combo so I'm stumped. I've got a pic but I've got to upload it.
69 C10 LWB (SWB now)
dlturner00 is offline   Reply With Quote
Old 02-26-2014, 07:12 PM   #2
dlturner00
Re: Front Wheel Clearance
Here's the pic.
[IMG][/IMG]
Old 02-26-2014, 10:38 PM   #3
dlturner00
Well, I guess I missed the rally wheel FAQ. Sorry, my bad. I guess I'll use some spacers for now. They are only temporary.
Old 02-27-2014, 03:43 AM   #4
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Or you can knock off the weights and use stick on weights. That's what I had to do with the 15x7s on my 70.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 02-27-2014, 10:55 AM   #5
cdowns
cdowns's Avatar
dont need wheel weights for a roller project
Old 02-27-2014, 11:23 AM   #6
dlturner00
I'd really like to run these for awhile. Even without weights, there's only about a 1/16" clearance on the tie rod. I'm afraid ther would be enough flex to rub sometimes. If I space them 1/4" do you think I would run into fender rub?
Edit: They are 15 X 8.
Old 02-28-2014, 03:56 AM   #7
HSRACER
HSRACER's Avatar
I use 15x7 rims up front
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline   Reply With Quote
Old 02-28-2014, 07:30 AM   #8
Andy4639
Old member
Andy4639's Avatar
Talking Re: Front Wheel Clearance
You can shave a little off the steering to. Shouldn't take a lot just enough to clear them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-28-2014, 09:50 AM   #9
dlturner00
That may be the answer, if I can find some. Right side is actually a little worse than the left. I'll go with some spacers until I get to the fenders and see what happens there.
Old 03-04-2014, 01:05 PM   #10
dlturner00
Somehow I didn't notice, but I discovered that I had 2 7" wheels an 2 8" wheels. These wheels were on an 85 donor truck I used. Don't know why there were 2 different sizes on that truck, it was completely stock. Dumb luck I guess. Still pretty tight in the tie rod but no rub.
Old 03-04-2014, 02:13 PM   #11
67ChevyRedneck
67ChevyRedneck's Avatar
A local member here just had the exact same problem. He had a bad vibration. His wheel weights were rubbed down from hitting and became unbalanced. He took his wheels and had them balanced using the stick on weights on the back/inside of the wheel (like they use on modern wheels).
These:
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
