Factory? Hole in the floor board some one identify for me please
Noticed right after I got my truck on the transmission hump right where it slopes up to go over the bell housing there is a hole in the floorboard metal and the black liner. It's clean cut, looks factory not like some hack cut it with a torch or saw. Is it factory for a truck with an option I do not have? If so what's it for and should there be a plug for it? I'm worried about carbon monoxide coming in the cab through the hole. Any ideas?
![]() Join Date: Feb 2011
Re: Factory? Hole in the floor board some one identify for me please
Maybe for a a/c drain from aftermarket A/C unit.
How big is it?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Exactly 1 inch
Oklahoma 60-66 Chevy/GMC truck facebook group |
![]() Join Date: Feb 2010
how bout another pic, but back out a little and give a little reference. its a little to close up.
![]() Join Date: Apr 2009
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
Awesome sounds like a reasonable answer
Should I be worried about carbon monoxide coming in the cab?
![]() Join Date: Oct 2012
Only if you an yer gal are on a high fiber diet.
Maybe not so much of a carbon monoxide concern, unless you have an exhaust leak up front, but I'd cover it just to reduce a draft in the cooler months.
Im going to have to agree with the Aftermarket a/c answer mine has 1" hoses that run from the unit into the floor at the location specified.
1964 Chevorlet Custom 10 350/350 ,ps,mb,A/c,BBW -Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=608625 1969 Chevy Nova 2 dr I6 250/powerglide 1967,68,69,70,71,72 Chevy Frankenstein |
Thanks for the help guys that answers my ? I'll most likely seal it up
