laying low
![]() Join Date: Mar 2001
Loosing coolant
My 06 crew cab with 5.3 has been loosing coolant for a few months. It's been gradually getting worse. So far I have not been able to locate the source of the leak. I was adding a quart a week and it's now up to near a gallon in less than a week. It does not drip on the concrete. It's not leaking from the heater core inside the cab. It doesn't appear to be getting in the engine oil. About the only place left for it to go is the combustion chamber. We never smell antifreeze. The engine runs great and we get no codes. It has about 130,000 miles on it. The one thing I have not checked this week is the tranny fluid. If the coolant was getting into the tranny cooler the fluid would register high and surely by now it would start slipping and acting up.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Re: Loosing coolant
maybe rent / borrow
Radiator Pressure Tester Kit so its under psi but not running, hot coolant burns ![]() |
laying low
Re: Loosing coolant
We have an appointment with a local shop next week. Maybe they can find the source.
Re: Loosing coolant
on my 2001 suburban I had the following leaks which were hard to detect. Check the water pump, the gaskets are known for failing. you might also check the quick connect plastic connection to the heater core. I also had a the seam on the radiator side tank leak with a hairline crack
Stepside67 2016 Silverado LTZ Crew Cab 2001 Suburban 2000 Sportside Reg Cab 4.8 (Stolen) 1967 SWB Stepside Project |
Re: Loosing coolant
Was water pump for me, but not in that high of volume.
Re: Loosing coolant
Replace the radiator cap, should fix it
If not pressure test it. You may have a leaking freeze plug...
Jason TEAM C10 HOT ROD POWER TOUR
689 Short Step 68 Step Trucks Sold: 70 GMC, 72 K5 Members met: Andy4639 GCncsuHD CSGAS zicc1835 hotrod farm truck Mingrao Bhelton brenthiggins |
laying low
Re: Loosing coolant
It's up to a gallon per week right now. No signs on the engine, frame or on the pavement where we park it. New rad cap already. Engine oil and trans fluid still pretty as can be.
Re: Loosing coolant
I don't know if this is accurate or not. And I can't remember where I heard it. So someone please let me know if this is right or wrong.
Gasket failure on intake can put coolant right into air/fuel mixture and it gets burned in combustion cycle.
Ed will be known as the Tiger Woods of the integration business |
![]() Join Date: Jan 2002
Re: Loosing coolant
i have had that problem /its the intake gaskets !!!! common on all newer trucks !! usually the "check engine lite will come on with a senser -upper intake code ? "
laying low
Re: Loosing coolant
This is true of the earlier Vortecs but not the 99 and ups. They have a dry intake as in no coolant passes through the intake manifold on these. thank you though.
laying low
Re: Loosing coolant
Well the truck went in for testing. They pressure tested the system then ran a bore scope in the cylinders and found #3 & 5 were white inside instead of black. That's where the coolant was going. The oil level is now well up on the stick too. Also apparently coolant doesn't make the engine oil milky like it used to or is it just water that does that?
It's time to yank the heads and fix this thing. They found a tsb regarding coolant loss and it mentioned something about certain aluminum heads and a drainback tube going through a coolant passage leaking. They didn't say whether it's something that can be resealed or if a replacement head is required.
laying low
Re: Loosing coolant
Well it turned out to be a cracked head. You can't even see it. The shop sent it to another shop to check it and found nothing. Then sent it to another shop that specializes in head work. He pressure tested the head and it showed up. He marked where it was bubbling out. It is around a headbolt hole.
I've had the truck for 2 years and it's never ran hot. It's been driven daily mostly by my wife and she is easy on it. It has 130,000 miles on it. Both heads were checked, only one was bad and it will be going back together tomorrow. Mama is getting happy again. ![]()
