02-27-2014, 12:00 PM | #1 |
How many of you guys are running 700r4's
I am diving in to this project of getting a 700r4. I know allot of people have done this but I can't find the info I am looking for. Who did you use for the trans build local or online, bowtietrans? TCI? Ex......? What stall are you guys running? TV kits? What are u doing for lock up? Ex.... What price range am I looking at or can expect?
Info on my truck 72 c10 swb. 383 stroker healthy with lumpy cam. Built th350 but looking for mor of a cruiser, hence the 700r4 swap. PLEASE HELP I AM GETTING MIXED INFO ON THIS SWAP. THANK YOU. PS: the search icon did not provide much info. |
02-27-2014, 12:10 PM | #2 |
Re: How many of you guys are running 700r4's
I ordered mine from Bowtie Overdrives about 11 years ago...no problems so far...knocking on wood.
I ordered everything I needed from them (except cross member) and everything went together well. Couldn't say about the price now...but I'm sure its on their site.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives |
02-27-2014, 12:21 PM | #3 |
replaced my th350 with a 700r4 about a month ago and its the best thing I have done. It really helped me because I drive my truck almost every day and do a lot of highway driving. I bought my lockup kit from TCI and had to have my driveshaft shortened 3". You will also need a corrector bracket kit for your TV cable hook up on your carb. I got mine for about $17 from summit. I did the swap myself in my garage and everything went pretty smooth. Just make sure you get the TV cable set up right.
02-27-2014, 12:22 PM | #4 |
I have bought 2 700R4's from Phoenix transmission. Liked them a lot. I had them behind a ZZ4 crate engine with a 2200 stall. If I ever need another tranny I will buy from them for sure
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
02-27-2014, 12:23 PM | #5 |
I know there are certain years you do not want if you look for a used one. I found mine in a junkyard, I cannot remember the good years but it was one of them. It is the 700R4 not the 700R4E which is the electronic version. I put Lokar linkage on it and hooked the lock-up to a switch (Lighted Button) on my dash. The speed cable doesn't connect without a ridiculously priced converter so I bought a GPS speedo. Mine shift perfectly. Makes me wonder why they ever needed a computer later.
02-27-2014, 12:45 PM | #6 |
Parts and more parts
I put a 700 R4 in my 84 GMC W/O a lockup converter. I have a 2300 stall, to match my cam and keep the truck from pushing itself through a stop light when sitting at one. I originally purchased mine from Premier Perfomance transmissions---JET bought them out several years ago. However I since have had my local tranny guy upgrade it more and it is a lot more tranny than it was from Premier.
The RPM change was a very noticeable and with a 3.73 geared rear end and a 383 stroker engine, I can pull down a steady 15 MPG on the hghway at 75+ MPH.
Frank |
02-27-2014, 01:22 PM | #7 |
I had mine built by a local shop in '97 for around $1100 with converter and adaptor plate to Olds. It has stood up very well. I have 4.11 tail gears and run about 2200 R.P.M. at 65 mph. I have an 1800 R.P.M. stall with lockup.
As you have a lumpier cam than I, you'll probably want a 2500 R.P.M. stall or so. Here is what I am using for lock up.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
02-27-2014, 01:48 PM | #8 |
I got mine in '98 out of a low-mileage '91 Corvette. Changed the tail housing and good to go.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
02-27-2014, 03:01 PM | #9 |
me 4 one
02-27-2014, 04:33 PM | #10 |
3:55 - 3:73 rear gears best for 700R4. other gears will work depending on how tall of rear tire used. project33.com has a good calculator.
02-27-2014, 05:12 PM | #11 |
Go to BowtieOverdrives.com. They have everything you need, will ship right to your door. Comes with great instructions and if you call them the will pick up the phone to help. First class place. Project "black Betty" is going to be using one
Seth Instagram: sethrosa11 My Build Thread: "Betty" http://67-72chevytrucks.com/vboard/s...d.php?t=613225 1966 C10 Patina: http://67-72chevytrucks.com/vboard/s...d.php?t=716802 1978 Big 10 http://67-72chevytrucks.com/vboard/s...d.php?t=771383 |
02-27-2014, 07:13 PM | #12 |
Just like to part out trucks!!
so what is a used 700r4 worth, I found that was rebuilt last year
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
02-27-2014, 09:26 PM | #13 |
Just fininshed this swap.
Was running a t350. The 700r4 sits behind a new ZZ4. Drive shaft shortenend about 3". Used the existing crossmember. Running a TV cable from a 93 Camaro. Rear ration 3.73 Purchased a Certified 700R4 from my local Buick dealer. It was from a 91 Corvette with a 2200rpm stall. Cost $1500. You can click on my build thread below for more info.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
02-27-2014, 09:46 PM | #14 |
I went with the 200-4R for mine. No driveshaft work to install it, the holes are in the correct place to slide the crossmember back, and the local transmission builder said they are better than the 700R4 in many ways.
Found an article supporting it, though it's a few years old. http://www.carcraft.com/techarticles...mission_build/ I've had the rebuilt/upgraded 200 in my truck for a year now with the 350, and no troubles at all. Everything I have read says it will handle the 402 big I'm going to install next month with ease.
Mark 71 C10 Cheyenne 12 Aprilia RSV4 |
02-28-2014, 12:05 AM | #15 |
I used Phoenix also,had them do the install also.Very pleased with their work.Very knowledgeable staff.Check out their web site,they arwe also in all the hot rod mags.
84 step side 87 swb |
02-28-2014, 01:09 AM | #16 |
Carpe manana
See the 700r4 installed in my K20 on the build thread linked in my signature below. I went with one from BTO - the owner had a 72 K20 and knew exactly what I needed for the swap.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
02-28-2014, 09:54 AM | #17 |
When you look to buy a used 700r4, look at the cooler line fitting area. You want one that has a curved line in the area. It looks like a rainbow. I believe it's the 88-93 yrs. those are the better yrs. I'll post up a photo of what I'm talking about once I get off work. Also, check out my build thread, about half way through, you'll see what upgrades you want. "Beast Sunshell", etc.
Daniel 68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594 Romans 10:13 Everyone who calls on the name of the Lord will be saved. |
02-28-2014, 10:00 AM | #18 |
02-28-2014, 03:17 PM | #19 |
Great Post. Getting ready to do the same swap. Great info here.
72 GMC 1/2 Ton |
03-02-2014, 04:01 AM | #20 |
Are you guys using a switch for the lock up converter? Let us know what u are using and what works best.
03-02-2014, 08:59 AM | #21 |
I forgot to post up that photo for you. You want the 87-93 yrs, they have the auxiliary valve body. You can see the curved line cast into the casing that runs through the top fluid cooler fitting, that's the quickest way to see you have the right yr.
03-02-2014, 11:11 AM | #22 |
Location: Fort Mitchell, AL (out the back gate of Ft Benning)
If you go the junkyard route, you can get a dipstick tube for a '90s Astro van to bring it out better. Used that in my 66 with a 700R4 and it cleared the heater box very well
SSG Walker Harris '72 Cheyenne Longbed '66 Panel '66 Short Stepside '65 Short Fleetside |
03-02-2014, 12:57 PM | #23 |
Been wanting to do this for a long time. 3 on the Tree is cool but this swap would def be nice.
James B. 1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful) 1971 Chevy Fleetside Shortbed 4X4 (White & Rough) |
03-02-2014, 03:15 PM | #24 |
A day late and $1 short...
I received a quote from Bowtie Overdrives recently, $1983.05 delivered to my house in Florida. Pricey, but it does include the converter (1800), TV system, lock up kit, shift linkage, and their installation kit.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
03-02-2014, 03:25 PM | #25 |
I don't have one in a 67-72 yet, but I have one in a 70 SS 454 El Camino and one in a 65 Chevelle with a 377 Stroker. I love being able to smoke the tires from a stop and cruise at 75.
I have two different shops here that I trust to do these trannys.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
