Old 02-27-2014, 01:33 PM   #1
Yellow '67
Yellow '67's Avatar
'67 Stepside Front Lowering ??
My '67 currently has Porterbuilt Stage 1 & Stage 2 bags etc. installed and I want to go static in the front. Can I lower the front 6 or 7 in. without major problems like A-arms to low or inner fender rubbing. You have to use stock headers don't you?
Yellow '67 is offline   Reply With Quote
Old 02-27-2014, 01:38 PM   #2
BMERDOC
BMERDOC's Avatar
Re: '67 Stepside Front Lowering ??
From what I've seen 5.5" is as low as you can go and not have any issues. Tire size should also be taken into consideration.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
