Old 02-27-2014, 01:58 PM   #1
6600DURAMAX
6600DURAMAX's Avatar
Another 2wd to 4wd ??
I know this has been asked a hundred times but I cannot seem to find the old threads. Ae the 2wd and 4 we'd frame rails the same. I am looking for a 4wd Shortbed frame but have the ability to convert a 2 we'd if the frame rails are the same. What about the rear of a 2wd leaf sorting truck. Are they the same hangers used on a 4wd frame?
Are the body mounts positioned the same as far as height goes?
I am not worried about the cross members as I am going the LS route and will have to fab stuff anyway
Thanks guys
1972 K5 Build - plans - LS3-6L80e-One Tons.....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 02-27-2014, 06:00 PM   #2
b454rat
Re: Another 2wd to 4wd ??
I only did one, a crew cab, and stuff between the two were different. Can't really comment on 1/2 or 3/4 ton.....
b454rat is online now   Reply With Quote
Old 02-27-2014, 08:00 PM   #3
dbash
No they are not the same.
4WD frame rails are straight (same dimension between rails) from about the cab back. 2WD are curved for the rear suspension.
4WD frames are 25% stronger give or take.
I would keep searching for a 4WD frame. My truck was a 2WD frame converted to 4WD by the PO and it was a happy day when I chucked that worn out 2WD frame and started building on the real thing.
You can see a 4WD frame in my build thread (click the blue text below)
Good luck on your build, their out there if you search CL.
http://67-72chevytrucks.com/vboard/s...d.php?t=509467
2008 Dodge 3500 Blue Tech
2013 Challenger SRT8 392
1972 Landcruiser Rock Crawler LS1
1969 4X4 Resto Mod
dbash is offline   Reply With Quote
Old 02-27-2014, 08:34 PM   #4
Billett
Billett's Avatar
General consensus on here is that it's cheaper to find a 4wd frame
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 02-27-2014, 10:21 PM   #5
6600DURAMAX
Ok I will continue down that road of looking for a 4wd frame. I search CL everyday just coming up with none so far in my area. I am looking at a 200 mile radius. Would travel further if I have to.
Old 02-27-2014, 11:05 PM   #6
6600DURAMAX
New update and ??'s
Found a longbed 4x4 - I would just need to section it down to a Shortbed
OR
Found a Shortbed 2wd with rear leaf springs
Which one will be easier to convert...?
Old 02-28-2014, 02:24 PM   #7
bhammer
Just stick to looking for a 4wd frame, they are a pain to find but it will be easier to rebuild off of that than trying to make a 2wd frame work. They are out there though, just have to look. I am in the process of a 4wd shortbed rebuild, I had to drive about 800 miles round trip to get decent frame. I may have an extra frame left over, won't know for a while though. Good luck....
bhammer is offline   Reply With Quote
Old 03-02-2014, 01:25 AM   #8
argonaut
argonaut's Avatar
If you buy the long bed 4x4 frame it is very easy to cut down. 12" from behind the rest cab mount, 8"of the very rear ends.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 03-02-2014, 01:12 PM   #9
OldCreek
OldCreek's Avatar
Some 2wd frames, i.e. GMC, are straight in the rear and have leaf springs… Some chevy ones are, also, iirc.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 03-02-2014, 11:22 PM   #10
6600DURAMAX
So if the 2wd had leafs then they have the same frame as a 4x4? Where the rear hangers the same for the rear leafs?
Old 03-03-2014, 01:18 AM   #11
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
The rear of the frame would be the same or at least workable. 2wd frames are different in the front where the 2WD crossmember bolts into the frame. If I remember correctly, the 4WDs frame rails sweep higher than the 2WD rails. Easily workable, but it would also be easier and less noticeable to shorten a long bed frame.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 03-03-2014, 08:03 AM   #12
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
The 2 wheel drive frame is pretty much the same shape at the front, your 4x4 engine cradle will bolt right in, you will have to change the front core support mounts for the 4x4 versions that have the spring hangers built in. There is a bump out on each side of the frame for the E brake cables that has to be cut out and patched in with flat steel...then you will have to bore about a 2" hole in that spot for the rear upper shackle mounts along with there mounting holes. The rear spring hangers on a leaf spring 2 wheel drive frame are different than the 4x4 hangers but no reason they won't work.
If you have access to a good long bed 4x4 frame your a lot better off shortening it for what your doing.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
