Rear end options?
Hey all, I just picked up a '68 Gmc 2500. The gears in the rear are crazy steep.
At 45 mph the motor's screaming. Not sure what rear end it is. Dana 60? 10 bolt, 8 lug & floating axles. T350 trans. Thinking about swapping in a 1/2 ton, 6 lug rear. Any ideas/suggestions would be appreciated. |
Re: Rear end options?
looks like a dana 60 to me ,could be wrong but pretty sure
Ratfab, I hope you don't mind me jumping in here but I have a similar situation. '70 C20. You probably have 4.57 ratio, mine is 4.10, but I wonder if a simple ring gear and pinion change to 3.54 is possible in the C20 rear ends. I'm sure someone here has the answer.
Case split on the Dana 60 ratios is 4.10 down and 4.56 up. So on a 4.10 you could regear to a 3.54 on the same case (open or posi). But with a 4.56 you need to replace the case to go down at all.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Thanks sstim. I was leaning toward a rear end swap anyway.
![]() Join Date: Dec 2011
A 3.54 gear swap is possible. I think the easier and cheaper way would be to swap to a 14 bolt since you already have leaf springs. I pulled a 14 bolt from an 87 four wheel drive suburban with a 3.42 gear. The spring perches mounted perfectly. I had to relocate the shock mounts and buy larger u bolts (since I didn't get them from the donor). The drive shaft even bolted back up.
That is a Dana 60. You could probably find a big or small 14 bolt pretty cheap with 3.73 or 3.54 gearing. That would allow you to keep 8 lugs. If you still need less gear you could go with taller tires.
Sounds like it's time to hit the junk yard. Thanks all.
![]() Join Date: Oct 2013
no matter what you do be sure to verify that "new" rear gears are what will work best with your drivetrain/tire size, etc - project33.com has a good calculator.
