Old 07-23-2003, 03:58 PM   #1
68-Mike
68-Mike's Avatar
Question What shift linkage & bracket w/ 700r4?
What shift linkage & bracket will fit on my '68 with a 700r4?
Will a TH350 or TH400 bracket set-up work from the '67-72 years?
Thanks,
Mike
7th year of '68 C-10 LWB Rebuild in progress. Drivetrain done. Frame stripped, painted & rebuilt. Body/paint next.
'18 Yukon
'04 Sierra 4X4
‘77 Chevy C-20 Camper Special
‘68 C-10
Shopping for a 69-72 4x4 Blazer or Jimmy
68-Mike is offline   Reply With Quote
Old 07-23-2003, 05:31 PM   #2
smokekiki
Mike
smokekiki's Avatar
Are you hooking up to the colum ?Also you will need a tv cable bracket.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 07-23-2003, 06:31 PM   #3
68-Mike
68-Mike's Avatar
700r4 column linkage
The 700r4 is in and running. Looking for the column linkage. I'm using a rigged '75 linkage and bracket that allows me to get from Park to Drive. Just can'tget down to 1st, plus it's pretty sloppy.
I've also heard about some folks using a Lokar kit. Anyone use these?
Any advice would help.
Mike
'18 Yukon
'04 Sierra 4X4
‘68 C-10
Old 07-23-2003, 06:57 PM   #4
breeh
Recovering 67-72 Addict
breeh's Avatar
This is what I used and it has worked great for a year now.
http://www.shiftworks.com/kugel.htm
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 07-23-2003, 07:20 PM   #5
rickspickuppart
the units breeh mentioned work great I have used several of them and never had a problem
rickspickuppart is offline   Reply With Quote
Old 07-24-2003, 07:51 AM   #6
smokekiki
Mike
smokekiki's Avatar
I don't have that set-up.Yet.Have either of you used the indicator lens they offer for the overdrive?
Old 07-24-2003, 09:09 AM   #7
00droptopSS
2.5/4 on 20's
00droptopSS's Avatar
I have the Lokar and it works great. Mine has very smooth operation.
62 C/10 SWB. Currently in ground up resto. Big back window cab, V8, auto. My wife's grandfather's truck.
1965 Mustang Vert - Shelby Clone
2005 Dodge SRT-10
My Old 72 SWB
00droptopSS is offline   Reply With Quote
Old 07-24-2003, 11:17 AM   #8
trucks72
trucks72
trucks72's Avatar
If you are using a factory column. You will never be able to go completly into 1st gear.
trucks72 is offline   Reply With Quote
Old 07-24-2003, 11:25 AM   #9
Project1970
14.1 @ 96MPH
Project1970's Avatar
I've heard a few things regarding 700R4's, first gear, and stock columns. Some say it can't be done period; some say it will work if you adjust it properly; and some say you can get the detent but the 700R4 will still shift out of first whenever it damn well pleases (seems odd )
I think I've got mine adjusted, but I still can't get it into first. One of these days I'm going to replace the linkage with something better, just because it's sloppy as all get-out anyway, and not too good trying to shift it down the track!
(FWIW, I'm using the linkage almost exactly as it was on the THM400 it replaced.)
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 07-24-2003, 11:57 AM   #10
smokekiki
Mike
smokekiki's Avatar
I think if I was worried about going into and holding first,I would use a floor shifter.
Old 07-25-2003, 09:50 PM   #11
Don Smith
I am using stock shift linkage and tilt column. I am able to get all gears with no problem.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
