02-27-2014, 09:31 PM | #1 |
would they work
Will this wheel work on the stock 5x5 bolt pattern disk brakes
02-27-2014, 09:48 PM | #2 |
Old member
Re: would they work
What size is it. I had 15" truck ralleys on mine for a long time and they cleared everything just fine.
02-27-2014, 09:49 PM | #3 |
Re: would they work
20s
02-27-2014, 10:08 PM | #4 |
Old member
Re: would they work
Well we need a little more info than that. What back spacing how wide?
I have 20" Boss 338's on mine. 20"x8.5" wide with 5.5" backspacing.
02-27-2014, 10:14 PM | #5 |
Re: would they work
I want to know if the will fit over this
02-27-2014, 11:05 PM | #6 |
the boat guy
Re: would they work
Maybe... what are the dimensions?
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
02-27-2014, 11:09 PM | #7 | ||
"I ain't nobody, dork."
Re: would they work
What rotor is that? Stock? Aftermarket? Did you ask American Racing Wheels?
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
02-27-2014, 11:14 PM | #8 |
Re: would they work
02-27-2014, 11:19 PM | #9 |
The Older Generation
Re: would they work
Why not go with these... LockDoc
02-27-2014, 11:21 PM | #10 |
20' Daredevil (Ret)
Re: would they work
02-27-2014, 11:27 PM | #11 |
Old member
Re: would they work
If you can tuck them under the fenders then go for it man!
Now for a more serious answer. I just had the rotors machined down so the Boss wheels would fit. They are aftermarket rotors that are in the picture of mine. Then I had to grind the hub cone down at the end to let the wheel cap work. Are these local wheels are you ordering off the net? I would try and see if they fit before buying.
02-28-2014, 04:50 PM | #12 | ||
Re: would they work
First thing I'd do is measure that hub on the rotor, and call American Racing Wheels. Straight from the horses mouth.
Gary
