07-23-2003, 04:35 PM | #1 |
Timing hlp
Need to know around what to time it too ? 350 pretty much stock brand new edelbrock 1406 600cfm dynomax headers, edelbrock torker2 intake accel hei cap and coil and accel pplug wires what u think ???
07-23-2003, 04:39 PM | #2 |
Spank 'em if you got 'em!
I don't know if I should respond since I just posted about idling problems, but the sticker on my air cleaner says 8 deg. btc.
Long Knight '71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick |
07-23-2003, 04:55 PM | #3 |
Fabricate till you "puke"
on the HEI, I would start about 10-12 BTDC. the Hei dist has (as a rule) less mechanical advance built into the dist as compaired to the old points dist. You might opt for a Crane adjustable advance can, & recurve to suit your driving habits. The crane kit has pretty good instructions on how to set it up. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
