02-28-2014, 03:06 AM | #1 |
69 to 72 balljoint difference
hey all i need to know whats different about the upper balljoints between 69 and 72 units. i have a 72 chassis with shortened control arms i want to return to factory of which i have a full 69 roller that i can use the parts off of an insight is greatly appreciated
02-28-2014, 03:28 AM | #2 |
Re: 69 to 72 balljoint difference
The difference in the ball joints is determined by what spindle you have, disc or drum.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
02-28-2014, 03:32 AM | #3 |
I have disk on the truck I want to put the 69 control arms on. Guess I can switch ballpoints? The lowers are all the same from 67-72?
02-28-2014, 07:30 AM | #4 |
Watch out for your cornhole !
Lower ball joints are 63-70 and 71-87 fitment.
