Old 07-23-2003, 04:37 PM   #1
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
Rough Idle
Hey everyone, I have a problem and need some help.
I have a 350, rebuilt 30 over, with a RV cam, Edel. 1406 carb, new vacuum can. Heads were done also. Oh, and I have headers and an Ignitor.
I can't get it to even out at idle. Will it ever smooth out with the RV cam? What degree BTC should I aim for before messing with other stuff. I have cured the vacuum leaks and all the plugs are firing (plugs look they way they should). Any suggestions? Thanks everyone.
Ro
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
Old 07-23-2003, 04:44 PM   #2
Dads72
Maybe try the adjustment screws on the front of the carb.?
Dads72 is offline   Reply With Quote
Old 07-23-2003, 04:46 PM   #3
Long Knight
did it, made a little difference but not much.
Long Knight
Old 07-23-2003, 05:00 PM   #4
crazy longhorn
Fabricate till you "puke"
How big is the cam(dur@ .050)? Also, how much vacumn does the eng run @ idle?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-23-2003, 05:02 PM   #5
Long Knight
Let me pull the papers tonight. Sorry, should have included that info for the cam.
Long Knight
Old 07-23-2003, 05:28 PM   #6
oldsub86
Did you get the intake on smoothly without damaging the seal front and back? Vacuum leaks can make it hard to get a smooth idle.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 07-24-2003, 09:37 AM   #7
Long Knight
Here is my cam info:
Comp Cam Part # 12-207-2
Gross Valve Lift In: .42 Ex: .451
Duration @ .050: In: 203 Ex: 212
Lobe Lift In: .281 Ex: .301
I know how a cam works but I don't know how to read the specs. Anyway, here it is.
Long Knight
