Old 02-28-2014, 12:11 PM   #1
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
No-SPIN Differential INFORMATION
I got his envelope today, that was to be included in the glove compartment ( dispatch box ) when the NoSPIN differential was optioned..
Front of envelope. 4 7/8" x 7 3/8"
Back
2nd envelope inside of first. Blank on the back. 4 1/2" x 6 3/4"
This single page is folded in three. 6 1/2" x 10"
Fold out. Front page. Folded out completly 6 1/2" x 15 5/8"
Booklet. 4 1/8" x 6 5/8"
Old 02-28-2014, 12:18 PM   #2
1963c-10
1963c-10's Avatar
Re: No-SPIN Differential INFORMATION
Aerotruk63....that looks a lot different than the 17 spline Eatons like I have. The brochure you have is for the Detroit locker...correct?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 02-28-2014, 12:26 PM   #3
oem4me
Thanks for posting, Norm. Up until now, I've found the peculiarities of the no spin axle have been somewhat of a mystery and vary depending upon who is telling the story. This is great info, right from the source!
Old 02-28-2014, 12:27 PM   #4
aerotruk63
aerotruk63's Avatar
I would say yes. For the heavier than 1/2 ton trucks. I have the same Posi unit in my 63 and have another to put in the K10 eventually. The NoSPIN brochure says you can have it in the front differential of a 4WD as well. Wonder if these Eaton Posi's can go up front in a 1/2 ton?
1963 Silver Book
Old 02-28-2014, 12:37 PM   #5
1963c-10
1963c-10's Avatar
Thanks for sharing the literature. The Detroit locker is also the one pictured on the Posi cab tag.
Old 02-28-2014, 12:41 PM   #6
aerotruk63
aerotruk63's Avatar
Originally Posted by 1963c-10 View Post
Aerotuck63....that looks a lot different than the 17 spline Eatons like I have. The brochure you have is for the Detroit locker...correct?
and it aerotruk63 not Aerotruck63, you just don't care! lmao!
Old 02-28-2014, 12:43 PM   #7
1963c-10
1963c-10's Avatar
Aarg.....I do that all the time. Sorry. I'll get it right one of these days
Old 02-28-2014, 12:50 PM   #8
aerotruk63
aerotruk63's Avatar
Interesting KS10 on the envelope and the Cab Tag. Do you know what size/model/brand truck that tag's from 1963c-10?
By the way copy and paste my avatar in the future. lol
Old 02-28-2014, 02:06 PM   #9
1963c-10
1963c-10's Avatar
That tag came from a 62 c-20. I know its not the correct tag for the posi I'm using, but I wanted a back cab tag to put in the 63 when I install the posi. It was held in by 4 screws.
Heres the truck it came out of and the mounting location. From the pictures it looks to be directly above the driver side gas tank strap.
Old 02-28-2014, 02:13 PM   #10
aerotruk63
aerotruk63's Avatar
Thank you for the responce.
I hope you saved the grill guard as well?
Old 02-28-2014, 02:19 PM   #11
1963c-10
1963c-10's Avatar
No, not that one. But I found another after I got rid of the Smash Hit 61 grill guard. It was also off a 62, but I'm going to see if I can get it to work somehow with a 63 frame. The guy charged me $150, which I though was very reasonable.
This truck above was parted out here on the forum, and I believe another member did save the grill guard though.
Old 02-28-2014, 03:56 PM   #12
oem4me
by 1966 the tag had been downgraded from a plate to a mere sticker. It's location was approximately the same, behind the seat.
Old 02-28-2014, 09:20 PM   #13
factorystock
factorystock's Avatar
Wow, another ex Bell Telephone truck ( special order green paint). These C 20 No Spins have a problem of "racheting up" on left turns. Eventually they wipe out pinion bearings and your rear end howls going down the road. No problem, at 250K when this happened to me, I junked the 4.57 No Spin it and replaced it with a 4.10 standard differential, quiet again.
factorystock is offline   Reply With Quote
Old 02-28-2014, 10:24 PM   #14
pimpston65
pimpston65's Avatar
DEE-troit locker baby, hey oem4me Yelmer(mike) was looking for that same back of the seat sticker....
pimpston65 is offline   Reply With Quote
Old 02-28-2014, 11:29 PM   #15
yelmer
good info
yelmer is offline   Reply With Quote
Old 07-16-2014, 10:31 AM   #16
1963c-10
1963c-10's Avatar
There are some copies that were made by a forum member if anybody is interested. Link: http://67-72chevytrucks.com/vboard/s...d.php?t=635486
Old 07-16-2014, 12:18 PM   #17
Bears63
...just another truck junkie..
Bears63's Avatar
The switch to a sticker may have happened sometime in '63. My '63 C20 has the NoSpin rear and has a sticker in the cab, left side, behind the seat. I also have all the literature that came with it. It was in the glove box when I got the truck and is pristine.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 07-16-2014, 12:40 PM   #18
1963c-10
1963c-10's Avatar
Hey Bears63....where was your 63 assembled at? I'm just interested to see if there was a change at assembly plants or at a model year.
So far I can verify an aluminum tag on a 62, but unsure of plant location. And your 63 seems to be the 1st documented sticker cab that posted. I know its probably petty, but its the small details that really pull the period correct restorations together.
Old 07-16-2014, 02:19 PM   #19
Bears63
Bears63's Avatar
The small details are what help us solve the mysteries! My '63 C20 was assembled at the Janesville plant.
Mike "Bear" Shea
Old 07-16-2014, 02:31 PM   #20
1963c-10
1963c-10's Avatar
Ok, thanks. And I agree about the mystery solving. If the trucks had been documented as well as the cars we'd have a lot more info. But thanks to sites like this one I think we've accumulated quite a bit more than what was available 10 years ago.
Old 07-16-2014, 04:28 PM   #21
Jimal
Jimal's Avatar
Back
Interesting. Looks a lot like a Detroit Locker. Because it is and I should have searched first...
Jimal is offline   Reply With Quote
Old 07-16-2014, 06:58 PM   #22
oem4me
This is a bit like accurately dating an antique piece of silver based upon the ever-changing hallmarks. LOL. Notice all three tags/stickers posted have a different address shown.
Old 07-17-2014, 08:54 AM   #23
1963c-10
1963c-10's Avatar
the reproduction sticker was from a 67-72 truck if that helps identify that label any.
Old 07-17-2014, 09:16 AM   #24
Bears63
Bears63's Avatar
A little further information on my truck. I pulled the papers out last night to get the info. The vin is 3C254J126938 and it was delivered to the buyer on April 19, 1963.
Mike "Bear" Shea
