Old 07-23-2003, 05:40 PM   #1
Slick71
Slick71's Avatar
Will 35's fit with 4" lift?
I'm looking at buying a set of 35 X 14.5 X 16.5 Mickey Thompson tires on 16.5 X 10 M/T wheels. I've currently got a 4" lift and am wondering if these will fit or if I'll need to go up to a 6" lift. I'd rather not spend the extra $ on another lift if I can get by with what I've got.
1972 Chevy Blazer 4X4
Savannah, MO.
www.thefarmatadair.com
Slick71 is offline   Reply With Quote
Old 07-23-2003, 08:12 PM   #2
Pont
I need another Barley Pop
Pont's Avatar
I'm gonna guess that they will fit (with not a lot of room to spare) and are going to rub shortly after you turn the steering wheel. Depending on what backspacing those 10" wide rims have, they may even rub with a 6" lift. Maybe not!
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 07-23-2003, 10:50 PM   #3
MJN
MJN's Avatar
I've got 35's on my Blazer and they don't rub at all, I'm on my third set of them actually. 35x12.5x15 on 15x10 rims. I'm not sure if they will fit on '73-87 but for '67-72 they will.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 07-24-2003, 06:32 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I guess you would not be able to get a test fit prior to purchase? Those 14.5s will stick out past the rim further than 12.5s, that's on the inside and outside. On the inside you'll have to watch for spring contact if you have say more than 4" of back spacing, on the outside you have to watch the fang up front. If you can test fit the tires.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-24-2003, 07:17 AM   #5
86K10 Guy
35's fitment
I have an 86 K10 and have 35/12.50x15's and they fit fine, I have a 4 inch suspension lift (custom spring packs in the front/ 4 inch trailmaster 3 degree tapered blocks in the rear) , all with Rancho 9000 shocks on four corners and steering damper. They work great with no rubbing issues. Hope this helps. So I am figuring if you running 16.5 rims and couple inch widers tires that a lift would probably be necessary for rubbing issues..maybe one of the other guys will chime in here...thanks!
86K10 Guy is offline   Reply With Quote
Old 07-24-2003, 12:25 PM   #6
1969 GMC
1969 GMC's Avatar
could someone post a pic of a 67-72, 4" lift, and 35's?
thanx
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 07-25-2003, 12:55 AM   #7
wildwood
wildwood's Avatar
body lift
If it's the 14.5" Mickys you want, I think you'll need 6" of lift. 12.5s will fit fine but the extra width would probably rub in extreme conditions. Why not throw in a 2" body lift? You'll have plenty of room then. The only place you'll rub is the front corner of the front wheel wells, so you could cut that out like is done on some of the trucks on the show 4x4s thread. Then you probably wouldn't need any more lift. Or just buy 35 x 12.5s
You can't get out if ya don't get in
wildwood is offline   Reply With Quote
Old 07-25-2003, 01:06 AM   #8
wildwood
wildwood's Avatar
pic
This truck has 2.5" susp and 2" body. 35x12.5" rubber with no rubbing
Old 07-25-2003, 01:30 AM   #9
1969 GMC
1969 GMC's Avatar
oh man, I love that stance...I am gonna do that, except go 4" suspension and no body. ok, i might do body. thanks for the pic, sorry for hijacking post
1969 GMC K2500
1996 Honda Accord
Old 07-25-2003, 09:31 AM   #10
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here is a pic back when I was at 4" of lift with 35x12.50x16 on it. No rubbing but maybe if got crossed up it would have rubbed. I'm betting 14.50 width tires will rub.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-25-2003, 11:54 AM   #11
GMC71k20
heres36x14.5 with 6 inch lift
GMC71k20 is offline   Reply With Quote
Old 07-25-2003, 06:06 PM   #12
Slick71
Slick71's Avatar
Thanks guys for all the reply's. I think I'll talk the guy into a "test fit" before I buy em' like Jim recommended. I love the stance of that last truck posted by GMC 71 k20. I wonder what width of rim that is?
I often take the old rig deer hunting and crossing ditches, so I should probably stick to the 33's unless I go bigger on the lift. I don't want my tires rubbing on the fenders all the time.
Wildwood, nothing against body lifts, (I've got one on my new truck) but I just don't want to stick one on my old chevy. Thanks for the idea though.
Savannah, MO.
Old 07-25-2003, 11:53 PM   #13
wildwood
wildwood's Avatar
Last time I did a body lift it was on a 94 S10. I said I'd never do it again. But I did, and I like it! But if you want a susp lift then that's what you should get. Good luck
Old 08-08-2003, 10:09 AM   #14
72Bob
72Bob's Avatar
My 1969
My 3/4 ton 1969 with 4" lift and 35"x12.5x16.5 BFG's with el'cheapo 10" rims. Hope this helps.
72Bob is offline   Reply With Quote
Old 08-22-2003, 06:43 PM   #15
Slick71
Slick71's Avatar
Thanks for all the replies guys...how about fitting a 315X75X16 tire under a 71 with a 4" lift, mounted on a 10" wide wheel? Anyone ever run these new sized tires?
Savannah, MO.
Old 09-01-2003, 04:08 AM   #16
K5KRAZIE
Depending on the make, 315-75s will be a hair shorter than a 35-12.5......
TRUCKS
'72 K5
'06 mega dually
K5KRAZIE is offline   Reply With Quote
Old 09-02-2003, 06:48 PM   #17
Slick71
Slick71's Avatar
Thanks K5....I've found a set of 315 Durango tires for $250 with about 10K miles on them. I think that's the route I'm gonna go. Thanks again everyone for your help!
Savannah, MO.
Old 09-02-2003, 09:28 PM   #18
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Are they baja claw's cause if they are they will measure way smaller than what the side wall say's.. So I would say yes they would fit...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
