Brake Hose lenght...C10 4,5" drop
Hi guys!
Ive lowered my truck 4,5" at the front. Now my brake hoses are to long! Which is the right lenght of brake hoses that ive to buy? Can someone give me a link which ive to order? I just look at summit,but there no specified lengths!? Regards from germany Sascha |
Re: Brake Hose lenght...C10 4,5" drop
Too long?? I just lowered mine 5" and mine are too short and tight. I used 3" drop springs and a 2" drop spindle so maybe the way I dropped it changed my length different from yours.
#3 | |
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
![]() Join Date: Jul 2012
X3 here, 4/6 drop and used stock hoses.
My 71 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=548438 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Been there and learned the trick. Buy 3/4-1 ton hoses for 71-72 trucks. They are about an inch longer than half ton hoses but otherwise identical in every way. Most 67-72 specialty vendors sell them. I buy mine from Kenny's Trucks. I use them on all my lowered 71-72 trucks.
#6 | |
I've built the same truck a bunch of times basically. All my piles get drop spindles and springs for a total of 4.5 drop in the front. On the 71-72 trucks, that drop causes the brake hoses to be taught. About 15 years ago I mentioned this to Kenny at a swap meet and he showed me the 1 ton hoses. Exact same in all manners as the half ton hoses, except an inch longer. That extra inch gives enough slack to take the hoses out of a bind. Since then every 71-72 front end I've used under a truck, I buy the 1 ton hoses. Problem solved.
That is one cool bit of info right there
______________________ www.northeastrodrun.com |
Heres a BIG picture....!!!
![]() On the right side you can see that the house scratch at the lower arms! That is my problem! |
#10 | |
I found for my 1968 C10 the Corvette hose is an inch longer. Makes perfect for lowered 1968s.
| Bookmarks |
